ZUBoard Letter of volatility
  • Subscribers 363 subscribers
  • Views 846 views
mtreed
mtreed over 1 year ago
Just searching for a LOV for AVNET ZUBoard 1CG
  • iksevas
    iksevas over 1 year ago
    It sounds like this request (or a similar one from another customer) has made it to the responsible team for the ZUBoard. Those kinds of requests typically require you to be working with the Sales/FAE teams at Avnet and you won't typically find that information available here.
  • tjaekel
    tjaekel over 1 year ago in reply to iksevas
    You can check, which non-volatiles memories are provided by the board:
    Example, booting from SD card should be non-volatile (except hard power down when written w/o to sync).
    You will find also a QSPI flash on board.
    Even using an USB memory stick possible, as non-volatile.
    What is your concern about such a LOV letter (and what does it tell us at the end?)
