ZUBoard ZUBoard PYNQ with eMMC device - how to build modified PYNQ repository?
  • Subscribers 363 subscribers
  • Views 861 views
tjaekel
tjaekel over 1 year ago
My approach to "patch" the PYNQ image with image.ub (using a modified device_tree) does not work.
(almost all works, just using Interrupts in overlay bit file (AXI IntC), fails: it does not find OUI and the interrupt vector 121 needed for it)
Now I am building a complete PYNQ image for the ZUBoard, from scratch.
Why is it so 'painful'?
I have to check the build log, try to figure out what is missing, what is not set, even modifying the build scripts (e.g. xcst was not found) ...
It takes >10 hours just to setup the build environment (assume one entire day just to setup all properly for a clean build).
And when it was running once completely to the end - I want to change now just my device tree in 'system_user.dtsi', in order to add
a node for mmcblk1 (eMMC module, mmcblk0 is the SD card).
Why is the buildzu.sh loading, compiling, installing ... all the time "all" again?
It takes hours (a half day) just to make a small modification in just one device_tree file.
(few lines of text added to device tree and the build process takes hours again - WHY?)
What is the fastest way just to compile PYNQ for ZUBoard again?
(make should realize what is unchanged, but the script seems to run almost all again, "rrrrr"
and it seems to fetch a lot of stuff again from Internet, including to fetch/submit something from/to GitHub - what is this build process doing?)
(unless just wasting my time)
Please,
who does have or could generate a PYNQ SD card image:
  • which would see, support the eMMC module (or even the SSD M.2 module, alternatively)
    as the PetaLinux does (but this PetaLinux image does not enable FPGA Manger or has Python (PYNQ) support integrated)
  • Please, please, ...
    just merge the eMMC (and SSD M.2) module into a ZUBoard PYNQ image. THANK YOU!
How get a ZUBoard PYNQ image which would "see" (support) eMMC (and/or SSD M.2) module?
  • tjaekel
    tjaekel over 1 year ago in reply to tjaekel +1 suggested
    For now, how to patch original ZUBoard PYNQ image for eMMC support: ZUBoard PYNQ - patch for eMMC support
  • iksevas
    0 iksevas over 1 year ago
    We received this same request today from you thru support channels and had a small discussion around this.
    Avnet currently does not have plans to perform this task with Pynq. You have seen many examples of the boards working with Petalinux as there are articles that show you how which you seem to have replicated.
    One option would potentially to look at a design services opportunity to get this task accomplished for you. Is this something your company would be interested in?
  • tjaekel
    0 tjaekel over 1 year ago in reply to iksevas
    "hmmmm" OK.
    Yes, it works with Petalinux (without PYNQ, no FPGA manager). But using PYNQ (esp. for using Python scripts and dynamic overlays) would be very important.
    Do you say: and mean?
    AVNET is not keen on supporting their other products, e.g. the AVNET eMMC module, SSD/M.2 module intended for the ZUBoard?
    "hmmm", disappointing... I had this board in mind as the best and feature rich PYNQ boards, intending to use many of those in our lab (>50).
    Now you are telling me: "no support"?
    I am not looking for a "design service":
    It it Open Source and selling HW extensions for it should be supported by the providing manufacturer (AVNET).
  • tjaekel
    Please,
    see my thread - it works:
     AVNET ZUBoard PYNQ with eMMC - WORKS!
  • tjaekel
    0 tjaekel over 1 year ago in reply to tjaekel
    Donate $1 when downloading my ZUBoard PYNQ eMMC image...  LOL
  • tjaekel
