ZUBoard ZUBoard 1CG - AMD EDF 2025.2 build example
  • Subscribers 363 subscribers
  • Views 752 views
  • ZU Board 1CG
  • edf
Tim5000
Tim5000 8 months ago
Hi has anyone tried to build linux/uboot for the 1CG using the 2025.2 AMD EDF?
I've recently had an opportunity to dig my board out again and I'm trying to run it using the latest toolchains as petalinux is being deprecated.
My previous toying with this were simple ones based on the Adam Taylor ones back in 2023 using petalinux loaded via tftpboot.
I've regenerated the XSA and Vitis artifacts using the 2025.2 Vivado and Vitis applications but trying to get a successful Linux/u-boot build via AMD EDF v2025.2 seems to be eluding me.
Generating the SDT from the XSA appears to go OK but building eventually fails - it seems many things are trying to be built that aren't needed e.g.(mali GPU) so I've ended up with a lot of things modified in my local.conf and still no success which makes me think it's not correctly targetting the board.
meta-avnet doesn't appear to be updated for some time.
  • iksevas
    iksevas 8 months ago +1
    Unfortunately, we have not extended the support for the ZUBoard to 2025.2 yet and we have not attempted to work within the new AMD EDF process. The last support for meta-avnet is 2024.2 which should be…
  • thill
    thill 6 months ago in reply to iksevas +1
    Hi there, I'm an Avnet FAE and I built an EDF platform for ZUBoard using Codex. I'm new to EDF so it's hard to judge the quality of the result myself but it does boot, and I have terminal access via screen…
  • iksevas
    0 iksevas 8 months ago
    Unfortunately, we have not extended the support for the ZUBoard to 2025.2 yet and we have not attempted to work within the new AMD EDF process. The last support for meta-avnet is 2024.2 which should be translatable/importable to 2025.2 using the older flow.
  • thill
    0 thill 6 months ago in reply to iksevas
    Hi there, I'm an Avnet FAE and I built an EDF platform for ZUBoard using Codex. I'm new to EDF so it's hard to judge the quality of the result myself but it does boot, and I have terminal access via screen, ssh, and can ping both directions. I'm still working on developing this build so if this work would be useful for you guys I'm happy to share.
  • Tim5000
    0 Tim5000 6 months ago in reply to thill
    Hi thill yeah that would be really interesting to see what you've got!
  • thill
    0 thill 6 months ago in reply to Tim5000
    Tim, I sent you a friend request so I can message you directly.
