      • Japan
      • Vietnam
Avnet Boards Forums
  • Avnet Boards Forums
Avnet Boards Forums
PicoZed Hardware Design Can't boot Petalinux 2017.4 on Picozed using QSPI and eMMC
  • Replies 1 reply
  • Subscribers 335 subscribers
  • Views 468 views
  • qspi
  • avnet
  • petalinux
  • picozed
  • emmc
ycinar32
ycinar32 over 3 years ago
Hi, I'm trying to boot Petalinux on Picozed7020 + FMCv1 using QSPI and eMMC. I've made the configurations using petalinux-config.
boot image settings -> primary_flash
kernel image settings -> prinary_sd
SD/SDIO settings -> ps7_sd_1
Also the constant 0 feeding to the SDIO1_CDN pin in block design.
Why u-boot tries to boot using MMC Device 0?
U-boot gives that message:
Card did not respond to voltage select!
MMC Device 0 not found.
no mmc device at slot 0
  • c_chil
    c_chil over 3 years ago
    Hi ycinar32, sorry for the delay in responding,  I don't have a suggestion to share yet, but I'll try to help get you one.
