Monarch Go
  • Monarch Go
Monarch Go
Forum Azure OOB demo connection issue.
Join Monarch Go to participate - click to join for free!
  • Replies 7 replies
  • Subscribers 9 subscribers
  • Views 3067 views
  • monarchgo
skruglewicz
skruglewicz over 5 years ago
I had the demo working once with your Monarch free trial template.
I set it up from the helpful Workshop#2 video's and docs.
When the 7 day trial was up I created a new Monarch template on a new free trial version. I configured the MCU Project with the Device info as before.
But now when I debug the app,  it is doing some communication but the results are not showing up on the IotCentral dashboard.?
where is the data going?
DO I have to use a different MQTT broker?
I'm at a lost here?
Thanks in advance
Steve K
  • jafoste4
    jafoste4 over 5 years ago in reply to skruglewicz +1 suggested
    Hi Steve, Can you email this entire log? (you emailed me previously). In the first log you showed its acting as if there isn't a network connection. Are you able to try it in a different location perhaps…
  • skruglewicz
    0 skruglewicz over 5 years ago
    Hi jafoste4  #jafoste4
    Any thoughts on this?
    SteveK
  • jafoste4
    0 jafoste4 over 5 years ago in reply to skruglewicz
    Hi Steve,
    The things that can change when you create a new templace instance are the device info and primary key information.
    I'd probably start my debug by verifying the following files within your IDE are configured correctly for the new template/device.
    msft_Azure_IoT_cientcredential.h
    msft_Azure_IoT_cientcredential_keys.h
    If those are configured correctly please let me know and I can help further.
    -Josh
  • skruglewicz
    0 skruglewicz over 5 years ago in reply to jafoste4
    I'll check again, but I believe I followed your directions in your workshop part2?
    On Iot Central I opened my device which I created on my 2nd free 7 day template. I Opened the "Connect" dialog  and using the information to fill in the following info in the code
    1) In your MCU application, navigate to msft_Azure_IoT\demo section
    then open :
    msft_Azure_IoT_clientcredential.h
    Copy the Scope ID (ID Scope) and Device ID values to the header file
         #define clientcredentialAZURE_IOT_SCOPE_ID ""
         #define clientcredentialAZURE_IOT_DEVICE_ID ""
    Edit line #22, adding the Azure DPS provisioning service as the MQTT Broker Endpoint
    "global.azure-devices-provisioning.net"
    2) This application also includes some code to support the simpler Shared Access Signature (SAS) authentication. This requires SAS Primary Key for connecting your real device also needs to be added. While still in this Device      Connection window, click on Shared Access Signature (SAS) then copy to the clipboard the Primary key that is displayed…
    Back in MCUXpresso, under the msft_Azure_IoT\demo section that you accessed before, open
    msft_Azure_IoT_clientcredential_keys.h
    and edit line 14, adding the SAS Primary Key that you have just copied from the      Azure IoT Central application
         #define keyDEVICE_SAS_PRIMARY_KEY       ""
    I'll try again
    Steve K
  • skruglewicz
    Still no data in IoT cental
    Device and scope set
    and primary key set
    hope there is no hackable but here is the debug output maybe you can see something I can't
    [MCUXpresso Semihosting Telnet console for 'lpcxpresso55s69_aws_remote_control_Cellular_Head LinkServer Azure_Cloud_Config_Debug' started on port 59614 @ 127.0.0.1]
    0 0 [Tmr Svc] Starting GSM application!
    1 0 [Tmr Svc] Starting Cellular-IoT Hardware configuration...
    2 130 [Tmr Svc] Cellular-IoT Hardware configuration initialized.
    3 130 [Tmr Svc] Library initialized!
    AT+CFUN=1,1
    OK
    ATE0
    +SHUTDOWN
    +SYSSTART
    +CEREG: 2
    +CREG: 2
    +CEREG: 0
    +CREG: 0
    +CEREG: 2
    +CREG: 2
    Network registration status changed. New status is: Network registration status changed. New status is: Network registration status changed. New status is:
    OK
    +CEREG: 1,"3B00","00E6D203",7
    +CREG: 1
    AT+CFUN=1
    OK
    AT+CMEE=2
    4 6149 [USART_Handler_T] Searching for network!
    OK
    AT+CGMI
    5 6149 [USART_Handler_T] Not registered to a network (can be a SIM card error)
    SEQUANS Communications
    OK
    AT+CGMM
    6 6150 [USART_Handler_T] Searching for network!
    GM01Q-GO
    OK
    AT+CGSN
    7 6153 [USART_Handler_T] Connected to home network!
    354658090472009
    OK
    AT+CGMR
    UE5.2.0.1
    OK
    AT+CREG=1
    OK
    AT+COPS?
    8 6222 [Tmr Svc] AT Parser library initialized.
    +COPS: 0,2,"311480",7
    OK
    AT+SQNCTM="verizon"
    9 6222 [Tmr Svc] Wait to be connected to the network...
    10 6223 [USART_Handler_T] Operator number: 311480
    OK
    AT+CSQ
    +CSQ: 21,99
    OK
    AT+SQNCTM?
    11 6846 [USART_Handler_T] Network operator RSSI: -71 dBm
    +SQNCTM: verizon
    OK
    12 6849 [Microsoft Azure] [INFO ][INIT][6849] SDK successfully initialized.
    13 6850 [Microsoft Azure] [INFO ][MQTT][6850] MQTT library successfully initialized.
    AT+SQNSCFG=1,3,1450,0,600,50
    OK
    AT+SQNSCFGEXT=1,1,1,0,1,1
    OK
    AT+SQNDNSLKUP="global.azure-devices-provisioning.net"
    +SQNDNSLKUP: global.azure-devices-provisioning.net,52.168.180.95
    OK
    14 7093 [Microsoft Azure] Looked up global.azure-devices-provisioning.net as 52.168.180.95
    AT+SQNSD=1,0,8883,"52.168.180.95",0,0,1,0
    OK
    AT+SQNSSENDEXT=1,146
    > 160303008D01000089030333D9AFD4861232C9593F9C5886B626DE9C8EE04F518443A06D2D23A4F85B765500000AC014C02FC027C01300FF010000560000002A0028000025676C6F62616C2E617A7572652D646576696365732D70726F766973696F6E696E672E6E6574000D000E000C040304010303030102030201000A000400020017000B000201000016000000170000
    OK
    +SQNSRING: 1,536
    AT+SQNSRECV=1,536
    +SQNSRING: 1,536
    +SQNSRING: 1,536
    +SQNSRING: 1,536
    +SQNSRING: 1,536
    +SQNSRING: 1,536
    +SQNSRING: 1,536
    +SQNSRING: 1,109
    +SQNSRECV: 1,536
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
    OK
    AT+SQNSRECV=1,536
    +SQNSRECV: 1,536
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
    [Closed Telnet Session]
  • skruglewicz
    0 skruglewicz over 5 years ago in reply to skruglewicz
    Connected now but I keep getting this error after a while ?
    OK
    AT+SQNSSENDEXT=1,12
    +CME ERROR: operation not supported
    AT+SQNSSENDEXT=1,12
    15 8757 [Microsoft Azure] ERROR: Handshake failed with error code -0x1
    16 8757 [Microsoft Azure] [ERROR][NET][8757] Failed to establish new connection. Socket status: -1.
    AT+SQNSH=1
    OK
    17 8773 [Microsoft Azure] [ERROR][MQTT][8773] Failed to establish new MQTT connection, error NETWORK ERROR.
    18 8773 [Microsoft Azure] Connection refused!!
  • jafoste4
    Hi Steve,
    In the first log you showed its acting as if there isn't a network connection. Are you able to try it in a different location perhaps with a better network?
    -Josh
  • skruglewicz
    HI jafoste4
    Thanks for help
    Your right when I move my workstation to another location. I get better results,
    I forgot I was dealing with Cellular ...LOL.
    I'm now having better results.
