Dream SensorBoard
  • DreamBoard
  • Dream SensorBoard
Dream SensorBoard
Documents luislabmo's DreamBoard Design 724128 : The GreenDream
  • Author Author: luislabmo
  • Date Created: 13 Jun 2019 2:40 AM Date Created
  • Last Updated Last Updated: 6 Oct 2021 10:01 PM
  • Views 665 views
The GreenDream measures variables such as plant growth, ambient light, UV light, ambient temperature and humidity. The data collected by the Dream Board and an external capacitive soil moisture sensor is then used to trigger notifications, managing the irrigation system and to analyze the data collected for future analysis which can be combined with a time-lapse video thanks to the Dream Board camera module.
A system like this can be implemented indoors with a Wi-Fi module or at remote outdoor locations with a long range transmission module like LoRa or Cellular. In an ideal world the wireless modules should have the ability to transmit the data collected by the sensors to an IoT cloud provider and to operate on deep-sleep mode as a way to extend battery life.
Parts List
BUS / InterfaceI2CInter-Integrated Circuit Communications Protocol1
Direct Attach TypeSMDSurface Mount Device Connection Type1
Pressure16bit-110kPA +/- 1%Standard Resolution (16 bit) + Standard Atmospheric  (110 kPa) + Standard Accuracy  (± 1.0%)1
Magnetometer8-bitLow Resolution (8 bit)1
Camera1920x1080 @ 1fpsStill shots (1 fps) + Hi-Definition  (1920 x 1080)1
ColourRGB450 to 750nm1
HumidityStandard AccuracyStandard Accuracy (± 5.0%) from 0 to 100% RH1
LightUltraviolet SpectrumUltraviolet spectrum (peak wavelength 400nm)1
TemperatureEnhanced AccuracyEnhanced Accuracy (±1°C) from -40°C to 105°C1
  • temp sensor
  • ultraviolet
  • temperature monitoring
  • uv index
  • luislab
  • irrigation
  • plant health camera
  • watering
