Dream SensorBoard
  • DreamBoard
  • Dream SensorBoard
Dream SensorBoard
Documents icehawke's DreamBoard Design 739412 : EHL Sensor Alpha
  • Author Author: icehawke
  • Date Created: 16 Jul 2019 9:17 PM Date Created
  • Last Updated Last Updated: 6 Oct 2021 10:04 PM
  • Views 388 views
Parts List
BUS / InterfaceI2C or SPIInter-Integrated Circuit Communications Protocol or Serial Peripheral Interface Communications Protocol1
Direct Attach TypePin / SocketPin or Socket sensorboard connector1
Wireless TechnologyWiFi 5Ghz 802.11nWireless LAN 5Ghz IEEE 802.11n1
Sound130dB-100Hz to 20kHzSuperior (130dB max) + Noise Suppression (down to 100 Hz) + Audible Range (up to 20 kHz)1
Pressure24bit-126kPA +/- 1%High Resolution (24 bit) + High Pressure (126 kPa) + Standard Accuracy (± 1.0%)1
Magnetometer16-bitHigh Resolution (16 bit)1
AccelerometerHigh Res - Heavy DutyHigh Resolution  (16 bit) + Heavy Duty  (± 90.0 G)1
ColourRGB450 to 750nm1
LightInfrared SpectrumInfrared spectrum (peak wavelength 1000nm)1
ProximityActiveActive Sensing1
