Dreamboard-VS
  • DreamBoard
  • Dreamboard-VS
Dreamboard-VS
Documents DreamBoard Vs | Last 16 | ashok r's: Flyot
Join Dreamboard-VS to participate - click to join for free!
  • Author Author: patkelly
  • Date Created: 7 May 2015 9:40 AM Date Created
  • Last Updated Last Updated: 20 Jul 2015 2:06 PM
  • Views 905 views
DreamBoard Vs - Battle of the DreamBoards: It’s DreamBoard Vs DreamBoard.
"Fl(y)+(i)ot - It Can fly out your data into the cloud. this is a small size and smart board specially designed for IOT. ARM Single Core with DRAM and FLASH combination speed up the internet server application which is running on RTOS. Also it has the Bluetooth and NF for easy user configuration. It has Sensors like GAS, Temperature and Accelerometer. WiFi or Ethernet is used for Connecting to cloud. Using CAN you can connect your car to cloud. Also it has separate Modem interface and IO Ports." Created by asokfair
DreamBoard Vs | Last 16 | ashok r's: Flyot Vs box's: FreeNAS Board
  • r's:
  • ashok
  • r
  • flyot
  • dreamboard
  • dreamboard-vs
  • asokfair
    asokfair over 11 years ago +1
    About FLYOT: "Flyot" is specially designed for IOT application. It has ARM chip with several sensors and connectivity (BTLE , WIFI , USB and Ethernet), It looks all the way we can connect to the cloud…
  • asokfair
    About FLYOT:
    "Flyot" is specially designed for IOT application. It has ARM chip with several sensors and connectivity (BTLE , WIFI , USB and Ethernet), It looks all the way we can connect to the cloud. As it has internal modem support we can easily plugin SIM (3G) or USB dongle for internet connectivity.
    Mobile can be connected through BTLE/WIFI also you can configure the board through NFC interface.
    Additional Special features:
    1."Whatsapp"  notification and alert.
    2.Easy configuration through NFC
    3.3G USB Dongle support
    Thanks ,
    Ashok R
