DreamBoard
  • DreamBoard
DreamBoard
Forum MIDI interface and processor, how to start?
  • Subscribers 6 subscribers
  • Views 1066 views
  • midi
I'd like to make a MIDI box with multiple MIDI in and out ports as well as USB. I'd like it to function like most MIDI interfaces you can buy for computers but with the capability of running user made programs for processing incoming MIDI. I see that Dreamboard doesn't currently have MIDI ports available, so I hope that gets added in the future. However, I'd still like some advice on where to start with the rest of the board. I need it to be able to route, filter, and merge messages, process messages, generate its own, as well as generate its own stable and reliable MIDI clock signal. It should be able to function without connecting the USB port. The USB port would be used for routing messages into a computer but also for uploading programs.
  • gadget.iom
    gadget.iom over 10 years ago
    Midi is basically serial data sent at 31,250bps.
    So load your board with UART interfaces as required. The merging/processing/generation of signals is typically handled by the software and therefore doesn't fall within the hardware scope of this design programme.
    If you REALLY want to make this board a reality there is already hardware out there that is capable of achieving this.
