EXPLORE-NFC
  • EXPLORE-NFC
EXPLORE-NFC
Forum Explore NFC card emulation
Join EXPLORE-NFC to participate - click to join for free!
  • Subscribers 9 subscribers
  • Views 811 views
I'm using the card emulation. My problem is the following:
when I start explorenfc-cardemulation -t "message"
it says:
Card Emulation started.
I can read the message with my phone. I can update the emulated tag with my phone as well.
But once it is done, I don't know where to find the updated information on the emulated tag on the raspberry pi.
Normally, the documentation says that it should be on stdout, but I can find nothing there.... it is empty.
Do you know where to find it ?
antoine
  • michaelneurohr
    michaelneurohr over 11 years ago
    Hi Antoine,
    you are right. The card emulation application should really print the new message to the terminal. Are you using the latest Raspbian?
    Strange, that you can update the message, but don't see it printed to the terminal.
    Michael
    e14 Contributor over 11 years ago in reply to michaelneurohr
    Hi Michael,
    Have you managed to compile the cardemulation sample (from SW282911.zip)?  The instructions in its Readme.txt did not work for me.
    If the source code compiles, then it should be easy to fix the problem that Antoine described.
    stan
