EXPLORE-NFC
  • EXPLORE-NFC
EXPLORE-NFC
Forum Write with nfc-explorer
Join EXPLORE-NFC to participate - click to join for free!
  • Subscribers 9 subscribers
  • Views 931 views
I use my nfc-explorer with raspbian, i try the reading mode, poll, but i have a question is it possible to write some tags ?
I try some command like  ./explore-nfc write "data to write"     but nothing works
  • obst77
    obst77 over 11 years ago
    I dont know how to write Tags with this library
    but the Python library nxppy is really easy to use so I use nxppy for writing tags
    e14 Contributor over 11 years ago in reply to obst77
    Solved, write is Ok for now, looking now how to clone tag, impossible yet ..
    Regards
    hi
    I am using the Python library nxpp. Everything works BUT -> i want to set the uri identifier (0x00 or 0x01 (open website)) with "block_write" i only can set ascii characters?! How did you solved this problem?
    import nxppy
    mifare = nxppy.Mifare()
    # Select the first available tag and return the UID
    uid = mifare.select()
    # Write a URL
    mifare.write_block(3, b'   ') #SPACE
    mifare.write_block(4, b'UID   ') # UID BEGIN
    mifare.write_block(5, b'elem')
    mifare.write_block(6, b' ent1 ')
    mifare.write_block(7, b'4.com')
    mifare.write_block(8, b'UID') # UID END
