EXPLORE-NFC
  • EXPLORE-NFC
EXPLORE-NFC
Forum The name org.neard was not provided by any .service files
Join EXPLORE-NFC to participate - click to join for free!
  • Subscribers 8 subscribers
  • Views 1160 views
  • daemon
  • explore-nfc-ww
  • neard
  • nfc
Hello all,
I just get an Explore-nfc v1.6 FCC ID:2AASNEXPLORE-NFC-WW and I downloaded files here : EXPLORE-NFC - Exclusive from element14|NXP but I always get this error :
neardal_mgr_prv_get_all_adapters(): Error: 2:GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.neard was not provided by any .service files
No adapter found
I even downloaded NXPPY at https://github.com/svvitale/nxppy wich says : "Installation will take some time as it automatically pulls down and builds NeardAL, WiringPi, and the NXP Reader Library from souce."
I really don't understand this error, I'm searching for nfc daemon and i only found the neard-explorenfc service and it's running...
I activated SPI through raspi-config, I run the command dpkg -i with the downloaded files and even the dev packages
I use the 2016-02-09-raspbian-jessie.img image
Here is my lsmod result
Module                  Size  Used by
binfmt_misc             6414  1
cfg80211              399468  0
rfkill                 16799  1 cfg80211
evdev                  10552  4
joydev                  9427  0
snd_bcm2835            19739  3
spi_bcm2835             7216  0
bcm2835_gpiomem         3023  0
snd_pcm                75040  1 snd_bcm2835
snd_timer              19138  1 snd_pcm
bcm2835_rng             1824  0
snd                    52636  9 snd_bcm2835,snd_timer,snd_pcm
uio_pdrv_genirq         2986  0
uio                     8228  1 uio_pdrv_genirq
i2c_dev                 6108  0
fuse                   82598  3
ipv6                  343556  28
here is my dpkg query result
ii  libneardal-dev 0.14.2-1     armhf        C APIs for Neard NFC daemon
ii  libneardal0    0.14.2-1     armhf        C APIs for Neard NFC daemon
ii  neard-exploren 0.9-1        armhf        NFC daemon for the Raspberry Pi a
ii  wiringpi       2.31         armhf        The wiringPi libraries, headers a
What can I do ?
    I had the same problem and i solved it : install "glib1-mesa-dri" packet and the explorenfc-basic command works.
    I'm a newbie in nfc and i search how to work a nfc card and how to read this one, but i don't understand the "explorenfc-basic" programm (what is "UID ?, what is SAK/ATQA ? and how to read other cards? -> my school card for example), if you understand this please contact me and help me
    (Sorry if my english is bad, it's because i'm french)
    e14 Contributor over 10 years ago in reply to e14 Contributor
    Merci pour ta réponse (je suis aussi français image). J'ai essayé d'installer le package libgl1-mesa-dri (glib1-mesa-dri n'existe pas) en faisant cette commande :
    sudo apt-get install libgl1-mesa-dri
    Mais visiblement je suis déjà à jour :
    libgl1-mesa-dri is already the newest version.
    De ce que j'ai vu du guide d'utilisation, explorenfc-basic attend tout simplement la lecture d'une puce NFC et te renvoie les informations de la puce. D'après cette page ISO14443A - NFC Tools ces valeurs permettent d'identifier le constructeur des puces ainsi que le type de puce.
    En tout cas merci pour ta réponse, tu peux me donner plus d'informations sur l'image que tu as utilisée et les outils que tu utilises ?
    I try to understand the service issue, so I run this command :
    sudo service --status-all
    and I get this list :
    [ - ]  alsa-utils
    [ + ]  avahi-daemon
    [ - ]  bootlogs
    [ - ]  bootmisc.sh
    [ - ]  checkfs.sh
    [ - ]  checkroot-bootclean.sh
    [ - ]  checkroot.sh
    [ + ]  console-setup
    [ + ]  cron
    [ + ]  dbus
    [ + ]  dhcpcd
    [ + ]  dphys-swapfile
    [ + ]  fake-hwclock
    [ + ]  hdparm
    [ - ]  hostname.sh
    [ - ]  hwclock.sh
    [ + ]  kbd
    [ + ]  keyboard-setup
    [ - ]  killprocs
    [ + ]  kmod
    [ + ]  lightdm
    [ - ]  motd
    [ - ]  mountall-bootclean.sh
    [ - ]  mountall.sh
    [ - ]  mountdevsubfs.sh
    [ - ]  mountkernfs.sh
    [ - ]  mountnfs-bootclean.sh
    [ - ]  mountnfs.sh
    [ + ]  neard-explorenfc
    [ + ]  networking
    [ - ]  nfs-common
    [ + ]  ntp
    [ - ]  plymouth
    [ - ]  plymouth-log
    [ + ]  procps
    [ + ]  raspi-config
    [ + ]  rc.local
    [ - ]  rmnologin
    [ - ]  rpcbind
    [ - ]  rsync
    [ + ]  rsyslog
    [ - ]  sendsigs
    [ + ]  ssh
    [ - ]  sudo
    [ + ]  triggerhappy
    [ + ]  udev
    [ + ]  udev-finish
    [ - ]  umountfs
    [ - ]  umountnfs.sh
    [ - ]  umountroot
    [ + ]  urandom
    [ - ]  x11-common
    the neard-explorenfc service is running but I still have the error message. Please Help me !
