EXPLORE-NFC
  • EXPLORE-NFC
EXPLORE-NFC
Forum Save reading to a file or database [SOLVED]
Join EXPLORE-NFC to participate - click to join for free!
  • Subscribers 10 subscribers
  • Views 1316 views
I need to save the NFC reading result to a file or database and append timestamp and after continue waiting for a reading.
It's easy to do? Anyone can help me?
Thank's
  • clem57
    clem57 over 10 years ago
    Should be straightforward. Pick where and write code.
    e14 Contributor over 10 years ago in reply to clem57
    Thank's for your answer Clem,
    I'm a newbie, and I don't know how to start. Can you guide me?
  • crjeder
    crjeder over 10 years ago
    Which OS, programming language and which database?
    e14 Contributor over 10 years ago in reply to crjeder
    Thank's crjeder,
    Now i'm using raspbian. I'm not sure what language can I choose... I'm confortable using bash script.  It's possible?
    Finally, mysql or mariadb as db it's ok. If it's easy save the reading to a file, it's ok too,  after i know how to export to a db.
    Thank's again
  • crjeder
    crjeder over 10 years ago in reply to e14 Contributor
    UNIX has a very powerful concept named "pipes" which is was you need. You can read more about it e. g. here: Linux Tutorial - 11. Learn Piping and Redirection
    Basically to redirect the output of "nfc-read" to a file you do:
    nfc-read > file
    If you want to redirect to an other program do:
    nfc-read | db-import
    I already know about Pipes, but you give me a great idea. Thank's!
    By now I'm using this bash script...
    #!/bin/bash
    explorenfc-basic > temp_file.txt
    input=`grep UID temp_file.txt | cut -d " " -f 3`
    mplayer beep-07.wav
    mysql -u MYSQL_USERNAME -pMYSQL_PASSWORD -e "INSERT INTO table_name (field1,field2,field3) VALUES (NULL,'$input',CURRENT_TIMESTAMP)" database_name
    Thank's again!
