EXPLORE-NFC
  • EXPLORE-NFC
EXPLORE-NFC
Forum Desfire or Ultralight C authentification
Join EXPLORE-NFC to participate - click to join for free!
  • Subscribers 9 subscribers
  • Views 791 views
  • ultralight
  • desfire
  • authentification
I trying to authenticate to a Mifare Ultralight C but not found description or example of pCryptoDataParams and pCryptoRngDataParams.
phStatus_t phalMful_Sw_Init(
                            phalMful_Sw_DataParams_t * pDataParams,     /**< [In] Pointer to this layer's parameter structure. */
                            uint16_t wSizeOfDataParams,                 /**< [In] Specifies the size of the data parameter structure. */
                            void * pPalMifareDataParams,                /**< [In] Pointer to palMifare parameter structure. */
                            void * pKeyStoreDataParams,                 /**< [In] Pointer to phKeystore parameter structure. */
                            void * pCryptoDataParams,                   /**< [In] Pointer to phCrypto data parameters structure. */
                            void * pCryptoRngDataParams                 /**< [In] Pointer to the parameter structure of the CryptoRng layer. */
Someone he already try authentication with explore-nfc ?
Thank you in advance,
Kiwil
    Did you have any luck? I hope Desfire authentication is possible somehow.
  • clem57
    0 clem57 over 10 years ago
    Maybe this can help http://www.nxp.com/documents/application_note/AN1303.pdf
