EXPLORE-NFC
  • EXPLORE-NFC
EXPLORE-NFC
Forum explorenfc-basic -w --> Unknown option -w
Join EXPLORE-NFC to participate - click to join for free!
  • Subscribers 9 subscribers
  • Views 746 views
Hi!
I have purchased the explore nfc expansion board for my Raspberry pi. The Quick Start-Up Guide was a great help and I was able to install all components.
However if I want to use the basic functionality of writing to a tag I get the information that the option -w is not available at all. How is this possible? Reading is fine by using "explorenfc-basic".
Additional informations:
lsmod command:
Module                  Size  Used by
xt_conntrack            2939  1
iptable_filter          1260  1
ipt_MASQUERADE           974  1
nf_nat_masquerade_ipv4     1901  1 ipt_MASQUERADE
iptable_nat             1787  1
nf_conntrack_ipv4      13413  2
nf_defrag_ipv4          1287  1 nf_conntrack_ipv4
nf_nat_ipv4             4867  1 iptable_nat
nf_nat                 12683  2 nf_nat_ipv4,nf_nat_masquerade_ipv4
nf_conntrack           78043  5 nf_nat,nf_nat_ipv4,xt_conntrack,nf_nat_masquerade_ipv4,nf_conntrack_ipv4
ip_tables              11618  2 iptable_filter,iptable_nat
x_tables               13602  4 ip_tables,ipt_MASQUERADE,xt_conntrack,iptable_filter
cfg80211              420690  0
rfkill                 16659  1 cfg80211
8192cu                528485  0
i2c_bcm2708             5014  0
spi_bcm2835             7248  0
bcm2835_gpiomem         2995  2
uio_pdrv_genirq         2966  0
uio                     8235  1 uio_pdrv_genirq
rtc_ds1307              9690  0
i2c_dev                 6047  0
snd_bcm2835            19769  0
snd_pcm                74825  1 snd_bcm2835
snd_timer              18157  1 snd_pcm
snd                    52116  3 snd_bcm2835,snd_timer,snd_pcm
fuse                   81710  1
ipv6                  339514  36
dpkg-query -l '*neard*' '*wiring*' command:
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name              Version       Architecture  Description
ii  libneardal0       0.14-1        armhf         C APIs for Neard NFC daemon
ii  neard-explorenfc  0.4-1         armhf         NFC daemon for the Raspberry Pi and NXP
ii  wiringpi          2.24          armhf         The wiringPi libraries, headers and gpi
command uname -a:
Linux rpi29 4.1.7-v7+ #817 SMP PREEMPT Sat Sep 19 15:32:00 BST 2015 armv7l GNU/Linux
Thank you in advance!
Kind regards,
Dante
  • michaelneurohr
    0 michaelneurohr over 10 years ago
    Hi Dante,
    please make sure to use the latest version of the EXPLORE-NFC software. The first versions did not have the write feature.
    You can get the latest version from the related NXP website.
    Direct link: Neard EXPLORE-NFC – Using NeardAL with EXPLORE-NFC. This package contains all software packages to get started working w…
    After you installed the latest version, you can write with the following command:
    explorenfc-basic -t Text -w "My string"
    Michael
    0 e14 Contributor over 10 years ago in reply to michaelneurohr
    Hi Michael,
    correct answer, thank you!
    Dante
