EXPLORE-NFC
  • EXPLORE-NFC
EXPLORE-NFC
Forum Question about  EXPLORE-NXP NFC expansion board
Join EXPLORE-NFC to participate - click to join for free!
  • Subscribers 8 subscribers
  • Views 854 views
Hello , I have a question about the  EXPLORE-NXP NFC expansion board for Raspberry Pi.
This board contains 26 pins and it's the number of pins in raspberry pi.
My problem is That I need to use 3 pins from raspberry  as output ,
so I want to know if some pins of the EXPLORE-NFC expansion board
are not used by the raspberry in the case of Card Emulation.
Thank you .
  • michaelneurohr
    0 michaelneurohr over 12 years ago
    the EXPLORE-NFC board only uses the following pins of the Raspberry Pi:
    For use with the SPI interface (default):
    • Pin 1 or Pin 17
    • Pin 2 or Pin 4
    • Pin 6 or Pin 9 or Pin 14 or  Pin 20 or Pin 25
    • Pin 19
    • Pin 21
    • Pin 23
    • Pin 24
    For use with the I2C interface:
    • Pin 1 or Pin 17
    • Pin 2 or Pin 4
    • Pin 3
    • Pin 5
    Michael
