EXPLORE-NFC
  • EXPLORE-NFC
EXPLORE-NFC
Forum org.neard was not provided in .service files
Join EXPLORE-NFC to participate - click to join for free!
  • Replies 30 replies
  • Subscribers 11 subscribers
  • Views 5011 views
Hi All,
I bought a new NXP NFC device from element14 . I was trying the demo first as giving by element14. I was able to install all the files properly,but after installation when I was trying to run this command :-    explorenfc-basic -k
I was getting this error :-   GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.cinnamon.SettingsDaemon was not provided by any .service files
                                        No Adapter Found
Can somebody help me what is this error due to.
Thanks in advance.
  • michaelneurohr
    0 michaelneurohr over 11 years ago
    did you install all deb packages as described in the Start-up guide [1]?
    sudo dpkg -i libneardal<version>_armhf.deb libwiringpi<version>.deb neard-explorenfc_<version>_armhf.deb
    Did you enable the SPI interface?
    Michael
    [1] http://www.nxp.com/documents/application_note/AN11480.pdf
  • clem57
    0 clem57 over 11 years ago
    https://learn.adafruit.com/downloads/pdf/adafruit-nfc-rfid-on-raspberry-pi.pdf gives a detailed look at using this card.
    0 e14 Contributor over 11 years ago in reply to michaelneurohr
    Hi Micheal,
    I did install all the DEB packages. But I did not explicitly activated SPI. Let me try that once tonight.
  • michaelneurohr
    0 michaelneurohr over 11 years ago in reply to e14 Contributor
    The SPI interface is definitely not activated if didn't do it explicitly.
    Let me know if this solves the problem.
    Michael
    I have exactly the same problem. I did not follow the order in the installation, though: I activated SPI only after installation. Also I did not remove all peripheral when stacking the NFC board on top of the Raspberry Pi 2. But I can't see how this raises problems?
  • michaelneurohr
    Hi Sascha,
    you are right, the way you did the installation should not make it not to work.
    So let's try find the problem.
    Could you please provide the following info?
    • Output of the command "lsmod"
    • Output of the command "dpkg-query -l '*neard*' '*wiring*'"
    • Name and version of the system image you are using.
    Michael
    Thank you for helping me! I re-installed the operating system but the same error occurs.
    1.
    pi@raspberrypi ~/explore-nfc $ lsmod
    Module                  Size  Used by
    sg                     18207  0
    uas                    13203  0
    snd_bcm2835            18850  0
    snd_pcm                75388  1 snd_bcm2835
    snd_seq                53078  0
    snd_seq_device          5628  1 snd_seq
    snd_timer              17784  2 snd_pcm,snd_seq
    snd                    51667  5 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
    joydev                  8903  0
    hid_microsoft           3152  0
    spi_bcm2708             5153  0
    i2c_bcm2708             4990  0
    evdev                   9950  6
    uio_pdrv_genirq         2958  0
    uio                     8119  1 uio_pdrv_genirq
    2.
    pi@raspberrypi ~/explore-nfc $ dpkg-query -l '*neard*' '*wiring*'
    Desired=Unknown/Install/Remove/Purge/Hold
    | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
    |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
    ||/ Name           Version      Architecture Description
    ii  libneardal0    0.14-1       armhf        C APIs for Neard NFC daemon
    ii  neard-exploren 0.4-1        armhf        NFC daemon for the Raspberry Pi a
    ii  wiringpi       2.24         armhf        The wiringPi libraries, headers a
    3. Raspbian GNU/Linux 7 (wheezy).
    Cheers!
  • michaelneurohr
    Everything looks right on your system.
    SPI is active, all required packages are installed.
    In the meantime I tried to figure out how I could reproduce the problem.
    I disconnected the board and I tried a power supply which only provides 750mA current.
    However I've not been able to reproduce the error message.
    Did you get exactly the same error message like to original poster?
    The text
    The name org.cinnamon.SettingsDaemon...
    makes me think of some troubles with a cinnamon component which is not part of EXPLORE-NFC.
    Hi Micheal,
    It worked after I enabled my SPI interface.
    Thanks a lot man , you made my day!!
    This is the error message I have now.
    pi@raspberrypi ~/explore-nfc $ explorenfc-basic
    neardal_mgr_prv_get_all_adapters() : Error: 2:GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.neard was not provided by any .service files
    No adapter found
    I think I had the same error message as the poster before re-installation but I am not too sure anymore now that I have this one.
