EXPLORE-NFC
  • EXPLORE-NFC
EXPLORE-NFC
Forum Case?
Join EXPLORE-NFC to participate - click to join for free!
  • Subscribers 11 subscribers
  • Views 1299 views
  • raspberry
  • pi
  • explore-nfc
  • cover
  • nfc
  • case
Case?
Hi!
  I'm looking for a professional-looking case for a Raspberry + Explore-NFC card.
  Unfortunately, the card seems badly designed to properly fit on a B+ or 2, will I have to use an older B model?
  Is 3D printing the only option?
Jean-Marc
  • gadget.iom
    0 gadget.iom over 11 years ago
    I am not aware of any specific case to accommodate the Pi + Explore-NFC card.
    You could use a standard enclosure of course, just refrain from using a metal one.
    Other that that you could try 3D Printing one.
    0 shabaz over 11 years ago
    Whenever we want a nice look (and want to show the insides) we use clear plastic (probably acrylic) and mount the board(s) in a sandwich using spacers. Looks nice.
    That just needs a hacksaw or machine cutting, and sand+polished edges, or a laser cut.
    If you want to fully enclose it, there are plenty of enclosures available from Farnell as Paul mentioned, and holes/slots can be cut as desired.
    0 e14 Contributor over 11 years ago in reply to shabaz
    Standard cases don't fit because the Explore-NFC card is too long for a RPi B+! :-(
    I need a professional-looking case for a finished product...
  • pj.riviere
    0 pj.riviere over 9 years ago in reply to e14 Contributor
    Jean-Marc,
    I just have read your post. Have you found a solution for the professional case you were looking for?
    I am in the same situation.
    Thank you,
    Pierre-Jean
