EXPLORE-NFC
  • EXPLORE-NFC
EXPLORE-NFC
Forum how edit and apply the 'explorenfc-cardemulation' source?
Join EXPLORE-NFC to participate - click to join for free!
  • Subscribers 10 subscribers
  • Views 860 views
/* I'm not use English, so I do not speak English well, please excuse me
* Use the Google Translation
I download a SW282911 at the NXP.com.
And then do it this
' ' ' shell
$ mkdir build
$ cd build
$ cmake ../source
$ make
so when I run ' $ explorenfc-cardemulation' is success.
printed the 'Card Emulation started.'
And I fix the /source/main.c
Line Number 238:
printf("Card Emulation started.\n");
-> printf("My Card Emlation started.\n");
then $cd ../build
$ cmake ../source
$ make
I run '$ explorenfc-cardemulation' that result is
I think that printed the 'My Card Emulation started.' is right, but result is not.
How change the source and apply it?
  • michaelneurohr
    michaelneurohr over 11 years ago in reply to e14 Contributor +1 verified
    The card emulation binary that you are executing is the one installed into your system (/usr/bin/). To run the binary that you just compiled, please run ./explorenfc-cardemulation. That command with the…
  • clem57
    0 clem57 over 11 years ago
    Did you change more than you though by accident? Please remove the change and try again. If OK then we need to understand where you put the change in the code.
    Clem
    0 e14 Contributor over 11 years ago in reply to clem57
    No, I just fixed 1, in main.c
    Line No.238: printf("Card Emulation started.\n");
    (fix like->) printf("My Card Emulation started.\n");
    cmake & make is success but,
    run result is not changed.
    whene I delete the line( printf("My Card Emulation started\n"); ),
    also is not changed.
  • michaelneurohr
    0 michaelneurohr over 11 years ago in reply to e14 Contributor
    To run the binary that you just compiled, please run ./explorenfc-cardemulation. That command with the "./" runs the binary in the current directory.
    Michael
    0 e14 Contributor over 11 years ago in reply to michaelneurohr
    Oh, thanks,
    I used '$ explorenfc-cardemulation'
    '$ ./explorenfc-cardemulation'is right.
