    • Avnet Boards Community
EXPLORE-NFC
  • EXPLORE-NFC
EXPLORE-NFC
Forum Is there any sample code for sending a simple APDU command with the ExplorerNFC board?
Join EXPLORE-NFC to participate - click to join for free!
  • Replies 11 replies
  • Answers 2 answers
  • Subscribers 11 subscribers
  • Views 2948 views
Hi All,
I´m trying to send a simple APDU command to a contactless smart card with the ExplorerNFC board but I could not find a the library for it in the doc and source files.
Is it possible ? I would like for instance to send a command such as : 0x80 0x08 0x00 0x00 ?
Does anyone have a simple solution ?
Thanks in advance, Aurelien
    Former Member over 10 years ago +2
    Hi, I'm using Raspberry Pi 2 Model B 1. I just downloaded the sample (main.c) https://github.com/JohnMcLear/NXP-Raspberry-Pi-Card-Polling-Demo 2. Replace the NXP Reader Library (NxpRdLib_PublicRelease…
    Former Member over 9 years ago in reply to Former Member +1 suggested
    Michael, looks like your missing this in your code: $ diff ../../NfcReaderLibrary/read-HCE-Android.c read-hce.c 150c150 < phbalReg_RpiSpi_Init(&balReader, sizeof(phbalReg_RpiSpi_DataParams_t)); --- > status…
    I am looking for the same thing
    Do people code the library to demonstrate complexity?
  • clem57
    0 clem57 over 10 years ago
    I assume you saw NXP EXPLORE-NFC Quick Start Guide.
    C
    I cannot find the post now. Someone pointed out to download SW297933.zip from NXP website. There are documents on how to use the NXP-NFC-Reader-Library
    PN512 reader board :: NXP Semiconductors
    2. Replace the NXP Reader Library (NxpRdLib_PublicRelease) by the latest version (from neard-explorenfc-0.8)
    3. Update the CMakeLists.txt
    cmake_minimum_required (VERSION 2.8)
    project (card_polling)
    #file(GLOB_RECURSE SOURCE_TMP "*.c" )
    #list(APPEND SRC ${SOURCE_TMP})
    set(NXP_RD_LIB "nxprdlib")
    include_directories (
      "/usr/include"
      "/usr/include/glib-2.0"
      "/usr/lib/arm-linux-gnueabihf/glib-2.0/include"
      "${PROJECT_SOURCE_DIR}/wiringPi"
      "${PROJECT_SOURCE_DIR}/${NXP_RD_LIB}"
      "${PROJECT_SOURCE_DIR}/${NXP_RD_LIB}/intfs"
        "${PROJECT_SOURCE_DIR}/${NXP_RD_LIB}/types"
        "${PROJECT_SOURCE_DIR}/${NXP_RD_LIB}/comps/phpalSli15693/src/Sw"
    link_libraries(wiringPi glib-2.0)
    set(EXT_LIBS  pthread  m)
    add_definitions(-g -O0 -std=c99)
    list(APPEND SOURCE "${PROJECT_SOURCE_DIR}/main.c")
    source_group(src "${PROJECT_SOURCE_DIR}/main.c")
    file(GLOB_RECURSE SOURCE_TMP "${PROJECT_SOURCE_DIR}/${NXP_RD_LIB}/*.c" )
    list(APPEND SOURCE ${SOURCE_TMP})
    #source_group(wiringPi FILES ${SOURCE_TMP})
    #list(REMOVE_ITEM SOURCE "${PROJECT_SOURCE_DIR}/${NXP_RD_LIB}/ex/NxpRdLib.c")
    add_executable(${PROJECT_NAME} ${SOURCE})
    target_link_libraries(${PROJECT_NAME} ${EXT_LIBS})
    4. I can now send select AID commands and customized commands
    From the sample main.c, after UID is obtained, I add the followings
    memset(ats, 0, sizeof(ats));
    status = phpalI14443p4a_ActivateCard(&I14443p4a, 8, 0, 0, 0, ats);
    status = phpalI14443p4_Exchange(&I14443p4, PH_EXCHANGE_DEFAULT, CMD_SELECT_AID, sizeof(CMD_SELECT_AID), &pRecvBuf, &recvLen);
    DBG_PRINT("Select AID: %d\n", status);
    DumpHex("Select AID", pRecvBuf, recvLen);
    status = phpalI14443p4_Exchange(&I14443p4, PH_EXCHANGE_DEFAULT, CMD_CUSTOM, sizeof(CMD_CUSTOM), &pRecvBuf, &recvLen);
    DBG_PRINT("Get filesize: %d\n", status);
    0 Former Member over 9 years ago in reply to Former Member
    Thank you for your post Eric,
    I have downloaded the latest library "NFCReaderLibraryforPNEV512B-3.010_R3", however, the phpalSli15693 folder was not located. Also, I ran the sample code as is, however, the status return code at the line below indicates PH_ERR_INTERFACE_ERROR  Communication error.
    Could you give some guidance on this as to ways I could troubleshoot further to determine what the cause of the error may be or any hints as to what could be causing this.
    Error here, status code 0x20B:
    /* Reset the RF field */
    PH_CHECK_SUCCESS_FCT(status, phhalHw_FieldReset(halReader));
  • michaelneurohr
    0 michaelneurohr over 9 years ago in reply to Former Member
    I wrote some instructions including some example code here.
    https://github.com/michaelneurohr/NfcReaderLibrary/tree/raspberrypi
    Checkout the two files read-HCE-Android-README.md and read-HCE-Android.c
    Michael
    0 Former Member over 9 years ago in reply to michaelneurohr
    @Michael
    Compiling read-HCE-Android.c works fine, but running it I get an error immediately.
    $ sudo ./read-hce
    Start Example: Read NDEF from Type 4 Tag
    Line: 153   Error - (0x0789) has occurred : 0xCCEE CC-Component ID, EE-Error code. Refer-ph_Status.h
    Wolfgang
  • michaelneurohr
    Hi Wolfgang,
    did you kill the explore-nfc daemon running in the background in case you installed the EXPLORE-NFC software before? The daemon might have the EXPLORE-NFC allocated in your case.
    Michael
    Hi Michael,
    error message is the same, no matter if the daemon is running or not
    Wolfgang
    Michael,
    150c150
    >     status = phbalReg_RpiSpi_Init(&balReader, sizeof(phbalReg_RpiSpi_DataParams_t));
    Wolfgang
