Dev Tools
Dev Tools
Forum How to troubleshoot a WI-PI
  • Replies 11 replies
  • Subscribers 82 subscribers
  • Views 1811 views
Hey folks, my WI-PI only worked for one Day, I got it up and running yesterday, and today the blue LED wo'nt even light up. Can anyone suggest a troubleshooting method?
    shabaz over 10 years ago in reply to e14 Contributor
    The easiest may be to double-check your wi-fi password by (say) trying to connect a smartphone/tablet/laptop or something to your Wi-Fi network, so that it is 100% confirmed what settings work.
    It really should be as easy as https://www.raspberrypi.org/documentation/configuration/wireless/ so if this isn't working, I suspect it is a password issue.
    (I'm assuming your router is configured for WPA2 (or WPA-PSK) and not  WEP. If you're using WEP (obsolete 10 years ago) then it needs replacing).
    Alternatively, for now just use an Ethernet cable plugged directly from the Raspberry Pi to one of the switch ports on your router, but that is merely a temporary option until you get the wi-fi password sorted, if the
    location of the router is inconvenient.
