Dev Tools
Dev Tools
Forum Help ammeter
  • Replies 12 replies
  • Answers 6 answers
  • Subscribers 80 subscribers
  • Views 2343 views
Help ammeter
daviduarte
daviduarte over 8 years ago
Hello my friends ,
It is a pleasure to be here :
I would like to set up a current / power meter like this one here:
https://www.element14.com/community/docs/DOC-81426/l/single-phase-energy-meter-with-rogowski-coil-sensor-based-on-the-stpm01-and-stm8l152c6
Only for frequency up to 500khz (or at most 1Mhz).
What existed ready that I can enjoy?
Thank you all.
    genebren over 8 years ago in reply to daviduarte +2 suggested
    David, Attached is a part that might do the job. It is only one part of a system and would require some additional support hardware (not an off-the-shelf solution). I have used a very similar part in the…
    dougw over 8 years ago +2 suggested
    CQ-330G
    genebren over 8 years ago +1 suggested
    The current meter that you referenced is obviously not going to work. The current clamps will roll off on the higher frequency that you intend to measure. As to what might be appropriate will depend more…
    0 genebren over 8 years ago in reply to daviduarte
    David,
    Just a little confused.  It looked like you were measuring currents in the of 10mA to 6A, then you mentioned 'low current' above.  I guess it could be high current at low voltage and low current at high voltage, but whatever the combination, be safe.
    Gene
  • daviduarte
    0 daviduarte over 8 years ago in reply to genebren
    Ok, I got it.
    I'm just considering 6A being a low current.
    Only that.
    Thank you.
