Dev Tools
Dev Tools
Forum NXP - EXPLORE-NFC
  • Replies 19 replies
  • Answers 6 answers
  • Subscribers 83 subscribers
  • Views 5434 views
  • board
  • nfc
  • dev
  • pn512
  • pn532
NXP - EXPLORE-NFC
maurosmartins
maurosmartins over 12 years ago
Hello all,
I'm currently seeking for NFC solutions, and I've found this EXPLORE-NFC - NXP - ADD ON BOARD, NFC, FOR RASPBERRY | Farnell Portugal
this uses PN512 and I have already found other dev boards using PN532.
My question would be, what are the main differences between the two? would they be library compatible (communicating by SPI)?
Thanks in advanced,
Best regards, Mauro.
  • hadifikri
    hadifikri over 11 years ago in reply to hadifikri +1
    Never mind, I got it.
  • hadifikri
    hadifikri over 9 years ago in reply to julia-rakitina +1 suggested
    The library that I used with my pi (2 and 3) was downloaded from nxp website. You can get it from http://www.nxp.com/documents/software/SW3693.zip look for folder NxpNfcRdLib. I surely hope the library…
  • michaelneurohr
    michaelneurohr over 9 years ago in reply to julia-rakitina +1 suggested
    Hi Julia, you can find all required and up to date resources at NFC Reader Library|NXP The software you need is NFC Reader Library for Linux . Make sure to download version 4.040.05.011646. The corresponding…
  • hadifikri
    0 hadifikri over 9 years ago in reply to julia-rakitina
    In order to set the password/authentication keys, all you have to do is write the keys to the "Sector Trailer" for every sector that you wish to protect. Each sector trailer (Block 3 of every sector)  have <Key A><Access Bits><Key B> entries. You may set the password just as how you write to any block.
    1) Activate the tag : phpalI14443p3a_ActivateCard(..)
    2) Initiate the tag : phalMfc_Sw_Init(...);
    3) Authenticate the tag with the current keys : phalMfc_Authenticate(...);
    4) Write the Sector Trailer: phalMfc_Write(...);
    Caution:
    If you wrongly set the access bit, you might brick the tag for good.
  • julia-rakitina
    0 julia-rakitina over 9 years ago in reply to hadifikri
    Thank you very much for your response!
    And library is  https://github.com/christianeisendle/nxprdlib-kernel-bal  as I understand?
  • hadifikri
    The library that I used with my pi (2 and 3) was downloaded from nxp website. You can get it from http://www.nxp.com/documents/software/SW3693.zip  look for folder NxpNfcRdLib. I surely hope the library support has improved over the years.
  • julia-rakitina
    Dear hadifikri, I appreciate your answer.
    I am experienced  python/Java/javascript programmer and it is my new challenge with C, before I used Arduino boards sometimes.
    Could you please provide some details? What IDE should I use? How to run this examples? I found  SW3693 README but it is not for EXPLORE-NXP, asks for LPCXpresso IDE... image
    I feel stupid to ask such noob questions image,  but nobody  knows everything
    Thank you in advance image
  • michaelneurohr
    0 michaelneurohr over 9 years ago in reply to julia-rakitina
    Hi Julia,
    The software you need is NFC Reader Library for Linux. Make sure to download version 4.040.05.011646.
    The corresponding documentation that describes how to get started is AN11802: NFC Reader Library for Linux Installation Guidelines.
    Hope that helps,
    Michael
  • hadifikri
    Hi julia-rakitina,
    I've uploaded some of my test code here https://hadifikri@gitlab.com/hadifikri/nxp-explorenfc.git. It has some basic function of reading and writing and changing any sector authentication keys.
    B.t.w, I'm still using the old library from 2 years ago image I've provided some instructions there to get you up to speed...
  • julia-rakitina
    Hi hadifikri
    Thank you very much for your support! image
  • noeldkendall
    0 noeldkendall over 9 years ago in reply to michaelneurohr
    That version of SW3693 does not compile cleanly for me on raspian jessie. Errors in example 5. Rest of build is OK.
    The problem lies in example 5. sDiscLoop.sTypeVTargetInfo causes compile errors.
    Looks like an issue with how include switches are set when building on and for a Pi with a nfs-explorer board.
    Trying to untangle without going deep down a rabbit hole.
  • noeldkendall
    0 noeldkendall over 9 years ago in reply to hadifikri
    Abdul, do you know what version of SW3693.zip you downloaded? Current won't build cleanly on Raspbian Jessie June 2017.
