NI LabVIEW Community
  • NI LabVIEW Community
NI Forum AD5293 Communication Using LabVIEW
  • LabVIEW Challenge Blogs
Join NI LabVIEW Community to participate - click to join for free!
  • Replies 7 replies
  • Subscribers 133 subscribers
  • Views 1541 views
  • i2c
  • ad5293
  • ad5932
  • labview
umair1998
umair1998 over 3 years ago
I have Analog PID Controller using AD5293 Digital Potentiometers. My senior who made i2c communication using labview, in other words we are using labVIEW to change gains. I connected Device and relevants pins connection but when I try to update/write the value of resistance fiollowing errors appears
-Board Not Connected (When I close it, next error -USB Connectivity Error)
I traced the Vi and found that this error arising from the the Analog Devices Vi 5932, I searched specific Vi for AD5293 but I didn't found. Firstly Do you thing AD5932 software will work for Ad5293 chip? If not then how to communicate this chip?
I will specifically show you from where this error is arising when I open this Vi, first error comes from download firmware "Board Not Connected" and when I clode it second errors appears from case structre.
My senior who made this code in 2016 doesn't remember why this error is appearing, he didn't face this kind of problem at that time. Why Analog Devices are not providing specific software for AD5293 chips? Please help.
    michaelkellett over 3 years ago
    There may be  a typo in your question. The AD5932 is NOT a digital pot - it's a:
    "waveform generator offering a programmable frequency scan".
    On the other hand you may be attempting to use the AD5932 Vi to control an AD5292 - which is not likely to work.
    AD5292 and AD5293 look very similar.
    Jan Cumps over 3 years ago
    (After validating what part number it actually is), trace the process inside the Load FW bock. Also check the error it is giving. Your Senior replaced the real error with a fixed text mentioning USB. It may be a completely different cause.
  • umair1998
    umair1998 over 3 years ago in reply to michaelkellett
    Thanks, you're right. I just deleted AD5932 Vi and it worked for me. Thanks
  • umair1998
    umair1998 over 3 years ago in reply to Jan Cumps
    Thanks, I followed these steps to find the solution.
    shabaz over 3 years ago in reply to umair1998
    What was the solution?
    In case anyone else comes across the same problem that you had, it would help them to know what your solution was.
  • umair1998
    umair1998 over 3 years ago in reply to shabaz
    The Vi AD5932 was not for digital potentiometer and that was reason.
