Atmel Xplained Boards
  • Atmel Xplained Boards
Blog Atmel SAMA5D4 Xplained Ultra N00b help.
Join Atmel Xplained Boards to participate - click to join for free!
  • Date Created: 3 Apr 2015 7:38 PM Date Created
  • Views 1390 views
  • sama5d4
  • xplained
e14 Contributor
e14 Contributor
3 Apr 2015
Salutations all,
I wanted to tinker with the Atmel SAMA5D4 Xplained Ultra board as a learning tool to understand embedded Linux environments.
Not coming from an engineering background I could at least glean SOME understanding by going through the videos from Peter Oakes' posts on this board.
SAMA5D4 Xplained Ultra - Tips and Tricks #1 - Getting Displays up and Running
As an idiot following step by step instructions, getting the display up and running through the HDMI port was pretty fun.
Having discovered that I can follow instructions if I repeated the steps enough times, I thought I'd try my hand at compiling a simple Hello World program on the board.
Turns out that's not as simple as I thought... as I would need to install GCC on the board to even try and I am failing at that to begin with.
Any and all help and guidance would be appreciated.
Thanks in advance!
    e14 Contributor over 11 years ago in reply to noglitch
    Thanks!
    I'll give that a whirl!
  • noglitch
    noglitch over 11 years ago
    You can take advantage of the SDK packages that we built with the meta-atmel Yocto layer:
    SoftwareTools < Linux4SAM < TWiki
    I'm sure that you can easily cross-compile with this your first "Hello World" program...
