Atmel Xplained Boards
  • Atmel Xplained Boards
Forum SAMA5D3 Xplained extension boards
Join Atmel Xplained Boards to participate - click to join for free!
  • Subscribers 5 subscribers
  • Views 1383 views
  • cortex
  • sama5d3
  • arm
  • atmel
  • xplained
Let us know which extension boards already available in the market, you would like to be supported by the SAMA5D3 Xplained board.
For example, we inserted the WiPi in the USB Host connector of the board and the Linux distribution running immediately found the driver for it.
    Can you add LCD capacitive multi-touch options? like this
    http://www.pdaatl.com/doc/tm4300.pdf
    and thanks for your efforts !
    We used this Capacitive Touchscreen from PDA for our demos at Embedded World. It is fully supported by our Linux distribution and QT SDK.
    Crank software has developed a great demo for it too.
    According to my information Premier Farnell should be able to sell it to you shortly too.
  • gspdaatl
    0 gspdaatl over 12 years ago in reply to e14 Contributor
    As mentioned in Jacko's reply, we are in the final stages of launching new touch modules for use with the SAMA5D3 Xplained kit.  More details will follow very soon.  We will be offering a 4.3in TM4301 which is a TM4300 with an improved touch sensor design and the new LCD interface used on the SAMA5D3 Xplained kit.  Launching at about the same time or soon after will be 7in TM7000 which also has the new LCD interface.  Both modules remain compatible with the earlier ARM EKs (SAM9X5, SAMA5D3x-EK, etc.)
    In the meantime, here are links to relevant datasheets:
       TM4301:   http://www.pdaatl.com/tm4301.pdf
       TM7000:   http://www.pdaatl.com/tm7000.pdf
    - Greg
