Single-Board Computers
  • Single-Board Computers
Blog SDR and SBC: Cheap thrills with radio waves
  • Author Author: fustini
  • Date Created: 7 Apr 2014 2:56 AM Date Created
  • Views 5182 views
  • Comments 11 comments
  • realtek
  • beaglebone_black
  • open_source
  • sbc
  • single_board_computer
  • software_defined_radio
  • rtlsdr
  • usb
  • bbb
  • BeagleBone
  • sdr
  • bb_black
  • adafruit
  • rtl-sdr
fustini
fustini
7 Apr 2014
I recently gave a presentation on Software Defined Radio (SDR) at my hackerspace in Chicago, Pumping Station: One.  I've attached the slides to this blog post for reference.  After the talk, someone told me they had seen a program that maps out airplanes flying in one's area based on data received via Automatic dependent surveillance-broadcast (ADS-B) on 1090 MHz.   After a search, I found dump1090 which works with cheap DVB-T USB sticks with certain Realtek chipsets thanks to the rtl-sdr library
dump1090 by Salvatore Sanfilippo
https://github.com/antirez/dump1090
a simple Mode S decoder for RTLSDR devices
Here is how I built rtl-sdr on BeagleBone Black which is running Angstrom on eMMC:
opkg update
opkg install libusb-1.0-dev
git clone git://git.osmocom.org/rtl-sdr.git
I have further details of installation process in this GitHub Gist:
https://gist.github.com/pdp7/5503462
After installing, test if the USB adapter is recognized:
root@beaglebone:~# rtl_eeprom
Found 1 device(s):
0: Generic RTL2832U OEM
Using device 0: Generic RTL2832U
OEM
Found Rafael Micro R820T tuner
Here is how I installed dump1090:
git clone git://github.com/antirez/dump1090
cd dump1090/
export PKG_CONFIG_PATH=/usr/local/lib/pkgconfig/
make
Next edit the html for the web interface so that your location is displayed on the map:
vi gmap.html
To the program:
export LD_LIBRARY_PATH="/usr/local/lib/:${LD_LIBRARY_PATH}"
./dump1090 --interactive --net
You will then see ADS-B data start to fill the screen assuming you are nearby any flights.  I live in Chicago near O'Hare so I see a lot of traffic:
dump1090 also runs a web server on port 8080 which displays the flights atop Google Maps:
You can find out more details for each individual flight from websites like http://flightradar24.com/:
Here is a video of my setup in action:
Watching airplanes with Adafruit SDR on BeagleBone
https://www.youtube.com/watch?v=l65sBZ25be4
Cheers,
Drew
http://twitter.com/pdp7
imagenerp-sdr-20140331.pdf
    shabaz over 12 years ago +2
    I couldn't wait too long to try this out. I did it on debian, following your instructions, it was very smooth. Just a few changes compared to Angstrom. This was what I typed: apt-get install libusb-1.0…
    shabaz over 12 years ago +1
    Hi Drew, Great video, it really made it clear how this works! Impressive how well it works, and how quickly the data started to fill up. - I'm looking forward to trying it now.
    e14 Contributor over 12 years ago in reply to shabaz +1
    shabaz wrote: EDIT: just saw a few more, approaching 1am, but these aircraft refused to supply lattitude/longitude - possibly cargo planes I guess. I know there are all sorts of good reasons to broadcast…
    Hi Drew,
