RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Blog RIoTboard for newbies like me, part 2
Join RIoTboard to participate - click to join for free!
  • Author Author: ntewinkel
  • Date Created: 28 May 2014 3:35 AM Date Created
  • Views 826 views
  • Comments 5 comments
  • riotboard
  • sound
  • display
ntewinkel
ntewinkel
28 May 2014
Over the weekend I was able to fix the ethernet jack in my living room (it had a little mishap a while back where I tugged on a nearby cable and all the little wires popped loose from this port - oops!), so today I plugged the RIoTboard back in to try it out with the network connected.
That all worked seamlessly, just the way I like it!
I was able to use it kind of like a "regular" computer with the keyboard and mouse to surf the net a bit.
So while this is hooked up to my big TV, I thought I'd go to edx.org to watch a course video… and I was quickly reminded of that little bug with the playback speed. hehe oops. Oh well. hopefully the smart people in the crowd will figure out how to fix the Android image for this board to bring entertainment to the masses.
One other thing I ran into this time is that the display seems to run off the edges of my TV, so some buttons are half off and it's hard to tell what's there. Does anyone know if there's a way to adjust this without having to change things on the TV itself - other things work fine in that port and I don't want to always have to adjust settings back and forth.
Next time I'll see about getting the Google Play app installed.
Cheers,
-Nico
    e14 Contributor over 12 years ago +1
    Unfortunately that's a TV 'thing'. You need to set 'overscan' to off or '1-1 pixel mode' different manufacturers set it to different things. Overscan is a relic of CRT displays, it's not necessary for…
  • fvan
    fvan over 12 years ago +1
    Where are the cats ? Keep going, very interesting to read about you experiences and problems encountered using the RIoTBoard ! I'm sure this info will be useful for all the RIoTBoard Road Testers. Fre…
    e14 Contributor over 12 years ago in reply to fvan +1
    cats are in the overscan region, that's why you can't see them
  • ntewinkel
    ntewinkel over 12 years ago in reply to e14 Contributor
    hahaha true yes. They were both there threatening to bite cords and "accidentally" throw things to the floor. especially the little one.
  • ntewinkel
    Nooooo! Dang you, imperfect technology!! And where's my jetpack already!!??
    I'll see if I can find a setting for that, as everything on it is digital. And it sounds like the picture quality will even improve, which is always a bonus.
    Thanks for the info, and for the links.
    cats are in the overscan region, that's why you can't see them image
  • fvan
    Where are the cats ? image
    Frederick
    Unfortunately that's a TV 'thing'.  You need to set 'overscan' to off or '1-1 pixel mode' different manufacturers set it to different things. Overscan is a relic of CRT displays, it's not necessary for HD signals. There's the chance of interesting effects if you still have SD stuff though.
    Some useful reading on the subject:
    http://www.engadget.com/2010/05/27/hd-101-overscan-and-why-all-tvs-do-it/
    http://en.wikipedia.org/wiki/Overscan
