RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Blog Riotboard webserver : Part4 - Getting temperature updates remotely ..
Join RIoTboard to participate - click to join for free!
  • Author Author: tusharp
  • Date Created: 29 Aug 2014 5:19 PM Date Created
  • Views 647 views
tusharp
tusharp
29 Aug 2014
Contents:
Part1: Environment Setup
Part2: Monitering Temperature with Xtrinsic Sensor
Part3: Capture sensor data to database
Part4: Remote datalogger   <-- You are here
Okay most of the core activity related to this blog series has been done .
Lets try some php + mysql stuff to display our data collected earlier.
In blog 1 we have setup the apache,mysql,php.
so we got a server, database and webpage development tool ready .
We will create file to store currently read temperature:
# touch /var/www/sensor.txt
Now something should update this file with current temperature.
modifying xtrinsic_mysql.c by adding below code.
xtrinsic_mysql.c  -> xtrinsic_current_temp.c
//define a char buffer
char buf1[200];
//capture current temp to a file
sprintf(buf1, "echo %d > /var/www/sensor.txt",t_m);
system(buf1);
Complete code available in attachment : xtrinsic_current_temp.c.zip
Compiling and execute the above code :
# gcc xtrinsic_current_temp.c -o  xtrinsic_current_temp  -std=c99 $(mysql_config --cflags --libs)
# ./xtrinsic_current_temp
Next we will try to pull data from sensor.txt to our webpage
will use php to display current temperature.
current_temper.php
<HEAD>
<meta http-equiv='refresh' content='1;url='current_temper.php'>
</HEAD>
<?php
if (array_key_exists("sensor",$_GET )) {
    $temper = $_GET["sensor"];
    $file=fopen("sensor.txt","w");
    fwrite($file, $temper);
    fclose($file);
    echo $temper;
} else {
    $temper = file_get_contents("sensor.txt");
    echo $temper;
In Line2 we have added a 1s refresh to get automatic  temperature updates.
we will run in browser.
http://localhost/current_temper.php
so the current temperature is getting updated.
You need to download the "current_temper.php" and "line_graph" and "pChart.tar" to "/var/www" directory.
all available in the attachments.
pChart is a php library used to create graphs,charts and pictures and other cool stuff.
Let plot a line graph with temperature and time in Vertical & Horizontal axis.
line_graph.php
<?php
//ADD AUTO REFRESH HERE
define("PCHART_PATH", "/var/www/pChart");
set_include_path(get_include_path() . PATH_SEPARATOR . PCHART_PATH);
require_once "class/pDraw.class.php";
require_once "class/pImage.class.php";
require_once "class/pData.class.php";
// Connect to MySQL
$db = mysql_connect( 'localhost', 'root', 'root' );
if ( !$db ) {
  die( 'Could not connect: ' . mysql_error() );
// Select the data base
$db = mysql_select_db( 'db1', $db );
if ( !$db ) {
  die ( 'Error selecting database \'test\' : ' . mysql_error() );
// Fetch the data
$query = "SELECT temperature,time FROM sensordata";
#$query = SELECT * FROM sensordata WHERE time1 >= NOW() - INTERVAL 20 MINUTE;
$result = mysql_query( $query );
// All good?
if ( !$result ) {
  // Nope
  $message  = 'Invalid query: ' . mysql_error() . "\n";
  $message .= 'Whole query: ' . $query;
  die( $message );
$myData = new pData();
// Print out rows
while ( $row = mysql_fetch_array( $result ) ) {
$temperature = $row["temperature"];
$time        = $row["time"];
$myData->addPoints($temperature,"temperature");
$myData->addPoints($time,"time");
$myData->setAbscissa("time");
#$myData->setXAxisDisplay(AXIS_FORMAT_DATE,"H:i:s");
#$myData->setSerieOnAxis("temperature", 1);
$myData->setAxisName(0,"temperature");
$myData->setAxisUnit(0," C");
// specify colors
$myData->setPalette("temperature",array("R" => 240, "G" => 16, "B" => 16, "Alpha" => 100));
// define image object
$myGraph = new pImage(900,400, $myData);
//create a rectangle box
$box_Settings = array("R"=>225, "G"=>227, "B"=>226, "Dash"=>1, "DashR"=>190, "DashG"=>203, "DashB"=>107);
$myGraph->drawFilledRectangle(100,15,600,60,$box_Settings);
$myGraph->setFontProperties(array(
"FontName" => PCHART_PATH . "/fonts/verdana.ttf",
"FontSize" => 5));
$myGraph->setGraphArea(80,100,800,260);
$myGraph->drawScale();
$myGraph->drawText(350,47," Riotboard Temperature Graph",array("FontSize"=>20,"Align"=>TEXT_ALIGN_BOTTOMMIDDLE));
// output line chart
$myGraph->drawLineChart();
header("Content-Type: image/png");
$myGraph->Render(null);
// Close the connection
mysql_close($db);
lets try in browser to get some updates:
http://localhost/line_graph.php.
you will something as below.
So we got a nice graph .
The temperature can be accessed remotely from any browser, for this Riotboard has to be given a public IP and accessed over internet.
Incase you get some thing like this
we need a php gd library (graphics library for php)
# sudo apt-get install php5-gd
Restart apache to load newly installed modules.
# /etc/init.d/apache2 restart
or
# apache2ctl restart
with this we got a simple temperature monitoring system.
