RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Forum No Video Connection with Android Image
  • Subscribers 23 subscribers
  • Views 506 views
  • android
  • tv
  • resolution
  • riotboard
radiatortwo
radiatortwo over 12 years ago
I am having trouble to get the board working with my Philips TV.
I´ve set the uboot variables like this:
setenv bootargs console=ttymxc1,115200 init=/init nosmp video=mxcfb0:dev=hdmi,1920x1080M@50,bpp=32 video=mxcfb1:off fbmem=10M vmalloc=400M androidboot.console=ttymxc1 androidboot.hardware=freescale
Only changes to standard settings are the FullHD resolution and the refreshrate to 50 Hz because with 60 it isn´t working at all. (The TV is PAL not NTSC)
When I set this with the Android Image installed it won´t work. The TV says no supported signal.
But when using the Ubuntu Linux image it´s working fine and the resolution is set correctly.
Has anyone similar problems?
    I actually had the exact same problem on my Phillips PAL TV. Android wouldn't show up on the TV with the TV complaining about incompatible signals. Linux worked fine. And same Android image worked fine with other monitors. You can check out this thread for other reports: Screen Resolution with preinstalled Android
