RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Forum Kali on RIoTBoard....its possible?
  • Subscribers 22 subscribers
  • Views 1528 views
epsylon67
epsylon67 over 8 years ago
Did someone managed to install Kali <<https://images.offensive-security.com/arm-images/kali-2017.3-riot.img.xz>> on RIoTBoard?
I followed the instructions from <<https://docs.kali.org/kali-on-arm/kali-linux-riotboard>>,  and tried all methods to write on SD card but no success to boot in... image
Some help for a newbie would be appreciate!
Thanks!
PS: Link from Kali download area is invisible so if u want to download image follow above link.
  • szempy
    0 szempy over 3 years ago
    I suppose you don't have this files because i can't rebuild it.
  • PascalEngel
    0 PascalEngel over 3 years ago
    The instruction link is broken (404).
    Have you set the boot jumpers to boot from SD-Card? And did you use the SD-Card slot, not the µSD Slot?
    If you want to use your Riotboard otherwise:
    it is possible to build a current Kernel 6.3 and GCC 12 and also a current U-Boot with the buildroot master branch.
  • szempy
    0 szempy over 3 years ago in reply to PascalEngel
    I did try to build it but failed: gitlab.com/.../312
  • szempy
    So you mean this one: https://github.com/buildroot/buildroot
    Well i tried to build it but i only get a 4.8 MB rootfs.tar file in the image folder.
    Do you have maybe a config file to get a working linux to the board? Or some information on what i should do to make it work?
