RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Forum Bluetooth 4.0
  • Replies 10 replies
  • Subscribers 25 subscribers
  • Views 1104 views
  • bluetooth
  • ble
  • 4.0
Bluetooth 4.0
Which are the possibilities to connect a Bluetooth 4.0 interface to RiotBoard?
thks,
Pau
  • FreescaleTools_and_Software
    0 FreescaleTools_and_Software over 12 years ago
    It'd be through one of the USB ports via a dongle. I haven't tried myself, but maybe one of those that works OOTB with other boards would work, or at least lead you on the right path to getting it supported: https://community.freescale.com/search.jspa?q=*bluetooth*%20*usb*%20*dongle*
    Perhaps someone else can chime in with their experiences if they happen to try one.
    Hello, Pau!
    I was looking for an answer whether is it possible or not to use a Bluetooth USB dongle with the Riotboard (working on Android) and have found your question. Have you managed that somehow?
    Best regards,
    strom
    So far we've haerd nothing much on the bluetooth front, we know that the WiPi wifi adapter will be supported at some point with android, but isn't currently.
    tusharp any news about either ?
    getting bluetooth or wifi working on the RIoT with linux should be possible, but will probably require you to be able to re-compile the kernel if you want to stick with the ubuntu image.
  • tusharp
    0 tusharp over 12 years ago in reply to e14 Contributor
    WiPi : support is a must in Android, can confirm that image.
    Bluetooth: need to check with dev team on the supported USB devices.
    cross compiling works on usb-serial gadgets unless it stucks at  annoying Unknown symbol image error or Segmentation fault image on insmod. .
    0 e14 Contributor over 12 years ago in reply to tusharp
    Thanks a lot! Will wait for any good news about Android and Bluetooth.
    Best regards,
    strom
    Hello!
    As far as I know the Riotboard could be shipped with Android 4.3. On the developer.android.com web site I have found such kind of information about the Android 4.3:
    Bluetooth Low Energy | Android Developers
    Does it mean that Android 4.3 is capable to recognize a Bluetooth USB dongle, connected to an Android 4.3 device via USB or that only means that Android 4.3 applications are capable to communicate with BLE devices (for example in the case when Android 4.3 is installed on a smartphone, and the smartphone communicates with a BLE device) ?
    Best regards,
    strom
    Can't say if android can or not, but the problem is liable to be that the drivers haven't been built.  I tried a few usb BT dongles I have and there's no driver in the image to load, so almost irrelevant if the rest of android could theoretically handle them....
    whether it's as simple as rebuilding android with some extra drivers (there are instructions posted on how to rebuild it) I don't know.
  • tusharp
    It means android BLE is capable of querying ONLY to recognised (PID:VID should be available) devices.
    Correct,  Apps using 4.3 APIs and libraries will be able to use the newly introduced Android BLE.
    agrahambell and tusharp, thanks!
    Best regards,
    strom
  • tusharp
    The BT support is not much available as of now, but can expect one once the WiPi is fully supported in both Linux/Android platforms.
    Unless Android has its own userspace drivers to support USB-Serial on BT dongles.
