RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Forum Java on RIoTboard
  • Subscribers 24 subscribers
  • Views 586 views
Java on RIoTboard
I have been attempting to get java running on the RIoTboard, but unfortunately it looks like the linux version that is available is only compatible with the softfloat version of JDK 1.7. From 1.8 they oracle have only been release hardfloat versions which dont work on this board. Is there a newer or alternative linux build for the RIotBoard that supports hardfloat?
  • tusharp
    0 tusharp over 12 years ago
    From oracle page it seems like they removed the soft float ABI support , only Hard Float JDK8 is provided  for ARM.
    Fixed!
    The problem was that Java was referencing /lib/ld-linux-armhf.so.3 which does not exist on the system. When you look at /lib the only load file is /lib/ld-linux.so.3 so just soft link them and it works. Below is how I worked it out and what I did to fix it.
    Enjoy
    root@linaro-ubuntu-desktop:/opt/java/jdk1.8.0_06/bin# java
    -su: /usr/bin/java: No such file or directory
    root@linaro-ubuntu-desktop:/opt/java/jdk1.8.0_06/bin# strings java
    qwwBI
    libpthread.so.0
    _Jv_RegisterClasses
    libjli.so
    _ITM_deregisterTMCloneTable
    JLI_Launch
    __gmon_start__
    _ITM_registerTMCloneTable
    libdl.so.2
    libc.so.6
    abort
    __libc_start_main
    lib.so
    $ORIGIN/../lib/arm/jli:$ORIGIN/../lib/arm
    SUNWprivate_1.1
    GLIBC_2.4
    1.8.0_06-b23
    java
    root@linaro-ubuntu-desktop:/opt/java/jdk1.8.0_06/bin# ls /lib/ld*
    /lib/ld-linux.so.3
    root@linaro-ubuntu-desktop:/opt/java/jdk1.8.0_06/bin# ln -s /lib/ld-linux.so.3 /lib/ld-linux-armhf.so.3
    /lib/ld-linux-armhf.so.3  /lib/ld-linux.so.3
    root@linaro-ubuntu-desktop:/opt/java/jdk1.8.0_06/bin# java -version
    java version "1.8.0_06"
    Java(TM) SE Runtime Environment (build 1.8.0_06-b23)
    Java HotSpot(TM) Client VM (build 25.6-b23, mixed mode)
    TaDa!
