RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Forum Setting Audio output to Jack instead of HDMI
  • Replies 27 replies
  • Answers 2 answers
  • Subscribers 25 subscribers
  • Views 5198 views
  • audio
  • riotboard
bose
bose over 12 years ago
I am using the Debian Linux from agrahambell on my RIoT Board. Thanks for linux build.
I have loaded alsa package = alsa-base alsa-utils alsaplayer and other required pacakages.
In the alsamixer I have the audio output set to 'DAC'. Not sure what this means.
I need to play audio via the audio jack on an external speaker from the command line. So for that I have alsaplayer for this.
However when I try to play the audio file via aplay there is not sound via the audio jack.
Also I don't have HDMI TV to be able to check if the audio is coming from the HDMI or not.
My HDMI converter is connected to a Monitor via DVI-D conversion.
Kindly help me out with this problem.
Warm Regards,
Abhijit
    Someone else mentioned audio problems yesterday toward the end of the ask-the-expert thread, so I'm investigating at the moment.  line out did work at one point as I'd tested it at the time, but something has changed somewhere between then and now, so I'll have to backtrack to see if I can find it.
    HDMI audio isn't going to work at this point either I'm afraid. While some patches for this do exist, they're still in a state of flux and it's not clear what version if any will make the cut.
    As I've said before, mainline kernel isn't for everyone - things will be missing or get broken along the way.  It is important to work towards getting mainline functional though as it benefits everyone in the long term.  So your testing and letting us know of any problems is appreciated !
  • bose
    0 bose over 12 years ago in reply to e14 Contributor
    Thanks for your insight.
    I will try to flash to stock Ubuntu and check it once.
    The problem with the stock ubuntu is that its resolution requires me to connect the serial debug and change the boot parameters.
    If any one can help me with these U-boot parameters it would be really a big relief. As I still far behind my project in terms of making a Audio Video to work from this board.
    Thanks in advance.
    Warm Regards,
    Abhijit
    0 e14 Contributor over 12 years ago in reply to bose
    Take a look at http://www.element14.com/community/docs/DOC-68087/l/riotboard-updating-os-images-in-linux-environment which details how to get ubuntu onto an SD card. This should avoid needing to change anything apart from the boot switches.
  • bose
    I am flashing it the way as per the user manual.
    I just need help in getting the uboot configuration to change the hdmi video resolution.
    Please help me do that.
    Warm Regards,
    Abhijit
  • tusharp
    0 tusharp over 12 years ago in reply to bose
    hi abhijit,
    plz try the below
    MX6Solo RIOT U-Boot > setenv bootargs console=ttymxc1,115200 init=/init nosmp video=mxcfb0:dev=hdmi,1280x720M@60,bpp=32
    video=mxcfb1:off fbmem=10M vmalloc=400M androidboot.console=ttymxc1 androidboot.hardware=freescale
    MX6Solo RIOT U-Boot > saveenv
    Tushar
    When using my 3.15 kernel, can you try the devicetree file from https://docs.google.com/file/d/0B-WIc2IIJv2FY2Y3UWloQWQ1ZWs/edit?pli=1 you just need to copy it into /boot and reboot
    There's a new set of files comprising SDcard image, kernel and devicetree available at   https://drive.google.com/folderview?id=0B-WIc2IIJv2FQURpR2V0MkhhUjg#list which will have working audio.
    Just do
    apt-get update
    apt-get install alsa-utils
    speaker-test -c 2
    and you should get sound.
  • bose
    Thanks for the update.
    I am downloading this image and would try it out shortly.
    Warm Regards,
    Abhijit
  • bose
    0 bose over 12 years ago in reply to tusharp
    I have tried this with two alternate forms.
    setenv bootargs console=ttymxc1,115200 init=/init nosmp video=mxcfb0:dev=hdmi,1280x720M@60,bpp=32video=mxcfb1:off fbmem=10M vmalloc=400M androidboot.console=ttymxc1 androidboot.hardware=freescale
    Also:
    setenv bootargs console=ttymxc1,115200 init=/init nosmp video=mxcfb0:dev=hdmi,1366x768M@60,bpp=32video=mxcfb1:off fbmem=10M vmalloc=400M androidboot.console=ttymxc1 androidboot.hardware=freescale
    In both cases the stock linux doesn't change the resolution.
    Please let me know on this. It would be really helpful for all the other people who would like to use the stock linux than compiling their own.
    Warm Regards,
    Abhijit
  • tusharp
    this one won't work, check here  Limitation 1366*768.
    we used this one "1280x720M" and it works fine.
