RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Forum RIoTboard I2C mapping
  • Subscribers 24 subscribers
  • Views 1182 views
  • i2c
  • riotboard
forcem
forcem over 12 years ago
I have a simple JNI app to interface the I2C ports.  The problem I am seeing is that if I use /dev/i2c-3, the data and clock are active on the I2C-4 port (J13 pins 35 & 37) instead of the I2C-3 port (J13 pins 31 & 33).  If I change the program to use /dev/i2c-4 instead it fails on the open(), presumably because there is no /dev/i2c-4, only -0, -1, -2, & -3.  How are the I2C ports really mapped on the expansion connector?
  • forcem
    0 forcem over 12 years ago
    I just verified that using /dev/i2c-2 results in activity on I2C-3 (J13 pins 31 & 33).
    0 e14 Contributor over 12 years ago in reply to forcem
    Hi!, well as i recall in the hardware design the counting starts with 1 to 4 and in software the counting starts from 0 to 3
    so port i2c-0 in software corresponds to i2c-1 on hw, and i2c-1 on software corresponds to i2c-2 on hw and so on =).
  • tusharp
    0 tusharp over 12 years ago
    The mapping might trick you, need to probe on i2cdetect (oscillator will be good). the software /dev/i2c* has no direct one-on-one name mapping with their physical counter parts.
  • tusharp
    0 tusharp over 12 years ago in reply to forcem
    thats good.
    i2c3 sda was purposely used for Ethernet interrupt workaround.
    plz try using  physical i2c4 image.
