RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Forum hdmi not ready error
  • Replies 18 replies
  • Subscribers 25 subscribers
  • Views 3692 views
  • linaro
  • riotboard
arunmagesh
arunmagesh over 12 years ago
hello, i just installed linaro on my board. its connected to my monitor by hdmi,
i enabled the hdmi in cmd mode too. but it posts error like hdmi no ready in serial debug.
  • tusharp
    0 tusharp over 12 years ago
    which OS are you using Linux / Android ??
    plz share the link form where you downloaded the image.
  • tusharp
    plz share the error bootlog also.
  • arunmagesh
    0 arunmagesh over 12 years ago in reply to tusharp
    i am on linux linaro. downloaded from the riotboard.org
  • tusharp
    0 tusharp over 12 years ago in reply to arunmagesh
    the error belongs to the audio part, not the display.
    Display should work fine.
  • arunmagesh
    nope. no response in the display.
  • tusharp
    uboot params for HDMI :
    setenv bootargs console=ttymxc1,115200 init=/init nosmp video=mxcfb0:dev=hdmi,720x480M@60,bpp=32 video=mxcfb1:off fbmem=10M vmalloc=400M androidboot.console=ttymxc1 androidboot.hardware=freescale
    can you try the above in your uboot settings.
  • tusharp
    arun,
    as posted above, plz try and confirm.
    the above is the only setting in 3.0.35 BSP to get HDMI working.
  • arunmagesh
    i have tried this in the uboot cmd. still no use. tried several resolution too.
  • tusharp
    can you share the error log here .
  • arunmagesh
    U-Boot 2009.08-00695-g055df3a (Dec 25 2013 - 09:56:12)
    CPU: Freescale i.MX6 family TO1.1 at 792 MHz
    Thermal sensor with ratio = 185
    Temperature:   43 C, calibration data 0x5905115f
    mx6q pll1: 792MHz
    mx6q pll2: 528MHz
    mx6q pll3: 480MHz
    mx6q pll8: 50MHz
    ipg clock     : 66000000Hz
    ipg per clock : 66000000Hz
    uart clock    : 80000000Hz
    cspi clock    : 60000000Hz
    ahb clock     : 132000000Hz
    axi clock   : 198000000Hz
    emi_slow clock: 99000000Hz
    ddr clock     : 396000000Hz
    usdhc1 clock  : 198000000Hz
    usdhc2 clock  : 198000000Hz
    usdhc3 clock  : 198000000Hz
    usdhc4 clock  : 198000000Hz
    nfc clock     : 24000000Hz
    Board: i.MX6DL/Solo-SABRESD: unknown-board Board: 0x61011 [POR ]
    Boot Device: MMC
    I2C:   ready
    DRAM:   1 GB
    MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
    In:    serial
    Out:   serial
    Err:   serial
    Net:   got MAC address from IIM: 00:00:00:00:00:00
    ----enet_board_init: phy reset
    FEC0 [PRIME]
    Hit any key to stop autoboot:  3     2     1     0
    mmc3(part 0) is current device
    MMC read: dev # 3, block # 2048, count 8192 ... 8192 blocks read: OK
    ## Booting kernel from Legacy Image at 10800000 ...
       Image Name:   Linux-3.0.35-02871-ga35ffe3
       Image Type:   ARM Linux Kernel Image (uncompressed)
       Data Size:    3901664 Bytes =  3.7 MB
       Load Address: 10008000
       Entry Point:  10008000
       Verifying Checksum ... OK
       Loading Kernel Image ... OK
    OK
    Starting kernel ...
    Linux version 3.0.35-02871-ga35ffe3 (luofc@embest-tech) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20) ) #1 SMP PREEMPT Wed Oct 30 15:27:47 CST 2013
    CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
    CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
    Machine: Freescale i.MX 6Solo RIOT Board
    Ignoring unrecognised tag 0x54410008
    Memory policy: ECC disabled, Data cache writealloc
    CPU identified as i.MX6DL/SOLO, silicon rev 1.1
    PERCPU: Embedded 7 pages/cpu @8c008000 s5440 r8192 d15040 u32768
    Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 227328
    Kernel command line: console=ttymxc1,115200 init=/init nosmp video=mxcfb0:dev=hdmi,1280x720M@60,bpp=32 video=mxcfb1:off fbmem=10M vmalloc=400M root=/dev/mmcblk0p1 rootwait
    PID hash table entries: 4096 (order: 2, 16384 bytes)
    Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    Memory: 640MB 256MB = 896MB total
    Memory: 896840k/896840k available, 151736k reserved, 0K highmem
    Virtual kernel memory layout:
        vector  : 0xffff0000 - 0xffff1000   (   4 kB)
        fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
        DMA     : 0xf4600000 - 0xffe00000   ( 184 MB)
        vmalloc : 0xc0800000 - 0xf2000000   ( 792 MB)
        lowmem  : 0x80000000 - 0xc0000000   (1024 MB)
        pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
        modules : 0x7f000000 - 0x7fe00000   (  14 MB)
          .init : 0x80008000 - 0x8003c000   ( 208 kB)
          .text : 0x8003c000 - 0x80a9bd14   (10624 kB)
          .data : 0x80a9c000 - 0x80b0a600   ( 442 kB)
           .bss : 0x80b0a624 - 0x80b586cc   ( 313 kB)
    SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    Preemptible hierarchical RCU implementation.
    NR_IRQS:624
    MXC GPIO hardware
    sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
    Set periph_clk's parent to pll2_pfd_400M!
    arm_max_freq=1GHz
    MXC_Early serial console at MMIO 0x21e8000 (options '115200')
    bootconsole [ttymxc1] enabled
    Console: colour dummy device 80x30
    Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
    pid_max: default: 32768 minimum: 301
    Mount-cache hash table entries: 512
    CPU: Testing write buffer coherency: ok
    hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
    Brought up 1 CPUs
    SMP: Total of 1 processors activated (1581.05 BogoMIPS).
    print_constraints: dummy:
    NET: Registered protocol family 16
    print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal
    print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
    print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
    print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
    print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
    print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal
    ----ldb_init
    ----enable clko2
    hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
    hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
    hw-breakpoint: maximum watchpoint size is 4 bytes.
    L310 cache controller enabled
    l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x02050000, Cache size: 524288 B
    bio: create slab <bio-0> at 0
    mxs-dma mxs-dma-apbh: initialized
    print_constraints: VDDA: 2500 mV
    print_constraints: VDDIO: 3300 mV
    machine_constraints_voltage: VDDD: unsupportable voltage constraints
    reg-fixed-voltage reg-fixed-voltage.2: Failed to register regulator: -22
    reg-fixed-voltage: probe of reg-fixed-voltage.2 failed with error -22
    print_constraints: vmmc: 3300 mV
    SCSI subsystem initialized
    spi_imx imx6q-ecspi.0: probed
    usbcore: registered new interface driver usbfs
    usbcore: registered new interface driver hub
    usbcore: registered new device driver usb
    Freescale USB OTG Driver loaded, $Revision: 1.55 $
    mc_pfuze 1-0008: recv failed!:-5,80
    mc_pfuze: probe of 1-0008 failed with error -1
    imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
    mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed
    mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x3130302a
    MIPI CSI2 driver module loaded
    Advanced Linux Sound Architecture Driver Version 1.0.24.
    Bluetooth: Core ver 2.16
    NET: Registered protocol family 31
    Bluetooth: HCI device and connection manager initialized
    Bluetooth: HCI socket layer initialized
    Bluetooth: L2CAP socket layer initialized
    Bluetooth: SCO socket layer initialized
    i2c-core: driver [max17135] using legacy suspend method
    i2c-core: driver [max17135] using legacy resume method
    Switching to clocksource mxc_timer1
    cfg80211: Calling CRDA to update world regulatory domain
    NET: Registered protocol family 2
    IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
    TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
    TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
    TCP: Hash tables configured (established 131072 bind 65536)
    TCP reno registered
    UDP hash table entries: 512 (order: 2, 16384 bytes)
    UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    RPC: Registered named UNIX socket transport module.
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    RPC: Registered tcp NFSv4.1 backchannel transport module.
    PMU: registered new PMU device of type 0
    Static Power Management for Freescale i.MX6
    wait mode is enabled for i.MX6
    cpaddr = c0820000 suspend_iram_base=c08b8000
    PM driver module loaded
    IMX usb wakeup probe
    add wake up source irq 75
    cpu regulator mode:ldo_enable
    i.MXC CPU frequency driver
    JFFS2 version 2.2. (NAND) ÂCopyright 2001-2006 Red Hat, Inc.
    msgmni has been set to 1751
    alg: No test for stdrng (krng)
    io scheduler noop registered
    io scheduler deadline registered
    io scheduler cfq registered (default)
    mxc_mipi_dsi mxc_mipi_dsi: i.MX MIPI DSI driver probed
    MIPI DSI driver module loaded
    mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver hdmi
    mxc_hdmi mxc_hdmi: Detected HDMI controller 0x13:0x1a:0xa0:0xc1
    fbcvt: 1280x720@60: CVT Name - .921M9
    imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
    Console: switching to colour frame buffer device 160x45
    mxc_sdc_fb mxc_sdc_fb.1: Can't get fb option for mxcfb1!
    imx-sdma imx-sdma: loaded firmware 1.1
    imx-sdma imx-sdma: initialized
    Serial: IMX driver
    imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
    imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
    console [ttymxc1] enabled, bootconsole disabled
    imx-uart.2: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX
    loop: module loaded
    m25p80 spi0.0: unrecognized JEDEC id ffffff
    GPMI NAND driver registered. (IMX)
    vcan: Virtual CAN interface driver
    CAN device driver interface
    flexcan netdevice driver
    FEC Ethernet Driver
    fec_enet_mii_bus: probed
    ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
    fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
    fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
    fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    add wake up source irq 72
    fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
    fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
    fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
    fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
    hub 2-0:1.0: USB hub found
    hub 2-0:1.0: 1 port detected
    Initializing USB Mass Storage driver...
    usbcore: registered new interface driver usb-storage
    USB Mass Storage support registered.
    ARC USBOTG Device Controller driver (1 August 2005)
    mousedev: PS/2 mouse device common for all mice
    generic touchscreen driver, <@>.
    usb 2-1: new high speed USB device number 2 using fsl-ehci
    hub 2-1:1.0: USB hub found
    hub 2-1:1.0: 4 ports detected
    >>>>> ct365_get_vendor() called <<<<<
    Chip ID: 0x0
    Chip data allocation failed: 0x0
    i2c-core: driver [generic_ts] using legacy suspend method
    i2c-core: driver [generic_ts] using legacy resume method
    i2c-core: driver [isl29023] using legacy suspend method
    i2c-core: driver [isl29023] using legacy resume method
    snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
    i2c /dev entries driver
    Linux video capture interface: v2.00
    ----ov2656_probe
    ----mx6_csi0_io_init
    ----v4l2_int_device_register success
    mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
    mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
    i2c-core: driver [mag3110] using legacy suspend method
    i2c-core: driver [mag3110] using legacy resume method
    imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
    Bluetooth: Virtual HCI driver ver 1.3
    Bluetooth: HCI UART driver ver 2.2
    Bluetooth: HCIATH3K protocol initialized
    Bluetooth: Generic Bluetooth USB driver ver 0.6
    usbcore: registered new interface driver btusb
    sdhci: Secure Digital Host Controller Interface driver
    sdhci: Copyright(c) Pierre Ossman
    mmc0: SDHCI controller on platform [sdhci-esdhc-imx.3] using ADMA
    mmc1: SDHCI controller on platform [sdhci-esdhc-imx.1] using ADMA
    mmc2: SDHCI controller on platform [sdhci-esdhc-imx.2] using ADMA
    mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
    VPU initialized
    mxc_asrc registered
    Thermal calibration data is 0x5905115f
    Anatop Thermal registered as thermal_zone0
    anatop_thermal_probe: default cooling device is cpufreq!
    usbcore: registered new interface driver usbhid
    usbhid: USB HID core driver
    usbcore: registered new interface driver snd-usb-audio
    mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio
    Cirrus Logic CS42888 ALSA SoC Codec Driver
    i2c-core: driver [cs42888] using legacy suspend method
    i2c-core: driver [cs42888] using legacy resume method
    ----sab_sgtl5000_init
    ----enable clko_clk.
    sgtl5000 0-000a: Failed to get supply 'VDDD': -19
    print_constraints: 0-000a: 850 <--> 1600 mV at 1200 mV normal
    sgtl5000 0-000a: sgtl5000 revision 17
    mmc0: new high speed DDR MMC card at address 0001
    mmcblk0: mmc0:0001 MMC04G 3.57 GiB
    mmcblk0boot0: mmc0:0001 MMC04G partition 1 2.00 MiB
    mmcblk0boot1: mmc0:0001 MMC04G partition 2 2.00 MiB
    mmcblk0: p1
    mmcblk0boot1: unknown partition table
    mmcblk0boot0: unknown partition table
    asoc: sgtl5000 <-> imx-ssi.1 mapping ok
    imx_3stack asoc driver
    asoc: mxc-hdmi-soc <-> imx-hdmi-soc-dai.0 mapping ok
    ALSA device list:
      #0: sgtl5000-audio
      #1: imx-hdmi-soc
    NET: Registered protocol family 26
    TCP cubic registered
    NET: Registered protocol family 17
    can: controller area network core (rev 20090105 abi 8)
    NET: Registered protocol family 29
    can: raw protocol (rev 20090105)
    can: broadcast manager protocol (rev 20090105 t)
    Bluetooth: RFCOMM TTY layer initialized
    Bluetooth: RFCOMM socket layer initialized
    Bluetooth: RFCOMM ver 1.11
    Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    Bluetooth: BNEP filters: protocol multicast
    Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    lib80211: common routines for IEEE802.11 drivers
    VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    Bus freq driver module loaded
    Bus freq driver Enabled
    mxc_dvfs_core_probe
    DVFS driver module loaded
    snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:05:20 UTC (320)
    EXT3-fs: barriers not enabled
    kjournald starting.  Commit interval 5 seconds
    EXT3-fs (mmcblk0p1): using internal journal
    EXT3-fs (mmcblk0p1): 13 orphan inodes deleted
    EXT3-fs (mmcblk0p1): recovery complete
    EXT3-fs (mmcblk0p1): mounted filesystem with writeback data mode
    VFS: Mounted root (ext3 filesystem) on device 179:1.
    Freeing init memory: 208K
    Failed to execute /init.  Attempting defaults...
    modprobe: FATAL: Could not load /lib/modules/3.0.35-02871-ga35ffe3/modules.dep: No such file or directory
    Last login: Thu Jan  1 00:04:26 UTC 1970 on tty1
    * Starting Advanced Power Management daemon...        [80G
    [74G[ OK ]
    speech-dispatcher disabled; edit /etc/default/speech-dispatcher
    Checking for running unattended-upgrades:
    ERROR: v4l2 capture: slave not found!
    ov2656_read_reg:write reg error:reg=300a
    * Starting bluetooth        [80G Welcome to Linaro 11.10 (development branch) (GNU/Linux 3.0.35-02871-ga35ffe3 armv7l)
    * Documentation:  https://wiki.linaro.org/
    New release '12.04 LTS' available.
    Run 'do-release-upgrade' to upgrade to it.
    [74G[ OK ]
      [33m* [39;49m PulseAudio configured for per-user sessions
    saned disabled; edit /etc/default/saned
    1 Jan 00:05:47 ntpdate[5398]: no servers can be used, exiting
    root@linaro-ubuntu-desktop:~# ERROR: HDMI is not ready!
    asoc: can't open platform imx-hdmi-soc-audio.0
