RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Forum Unable to get anything working...
  • Replies 13 replies
  • Subscribers 25 subscribers
  • Views 2304 views
pfinucan
pfinucan over 12 years ago
So I got my RiotBoard.  Plugged in keyboard mouse, hdmi, ethernet, and power.
The andriod OS starts up but is mostly off the screen so it is unusable.  I can't get past the splash screen.  :-(
UPDATE:  Got past the splash screen on andriod using this from the user manual
Display with HDMI Only (Default mode)
Execute the following instructions in u-boot mode to configure for HDMI display mode;
  MX6Solo RIOT U-Boot > setenv bootargs console=ttymxc1,115200
init=/init nosmp video=mxcfb0:dev=hdmi,720x480M@60,bpp=32
video=mxcfb1:off fbmem=10M vmalloc=400M
androidboot.console=ttymxc1 androidboot.hardware=freescale
  MX6Solo RIOT U-Boot > saveenv
For linux...
I downloaded fsl-image-fb-riotboard.sdcard from dropbox (link is now gone) put it on a micro SD card.  Set the boot switch per the uSD settings (below).
                D1 D2 D3 D4 D5 D6 D7 D8
Serial Download  0  1  x  x  x  x  x  x
SD (J6, bottom)  1  0  1  0  0  1  0  1
uSD (J7, top)    1  0  1  0  0  1  1  0
eMMC             1  0  1  1  0  1  1  1
I get this in the debug terminal
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
pureg-dummy: no parameters
Bus freq driver module loaded
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NFS: Registering the id_resolver key type
blah
blah
ALSA device list:
  #0: imx6q-sgtl5000
  #1: imx-hdmi-soc
List of all partitions:
b300         3751936 mmcblk0  driver: mmcblk
  b301            8192 mmcblk0p1 00000000-01
  b302            8192 mmcblk0p2 00000000-02
  b303               1 mmcblk0p3
  b304         2621440 mmcblk0p4 00000000-04
  b305          524287 mmcblk0p5 00000000-05
  b306          524287 mmcblk0p6 00000000-06
  b307            8191 mmcblk0p7 00000000-07
b318             128 mmcblk0rpmb  (driver?)
b310            2048 mmcblk0boot1  (driver?)
b308            2048 mmcblk0boot0  (driver?)
b320         7761920 mmcblk1  driver: mmcblk
  b321            8192 mmcblk1p1 00033ad3-01
  b322          544768 mmcblk1p2 00033ad3-02
No filesystem could mount root, tried:  ext3 ext2 ext4 vfat fuseblk
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
Where can I get a linux img for an SD that works?  Like ANY image that boots.  Most of the links on the element14 or riotboard.org are dead.  How do you adjust the screen size on andriod? The whole thing is very frustrating.
Can't use this guide...
RIoTboard: Updating OS images in Windows Environment
no tools...
Not Found
The requested URL /downloads/riotboard/tools_SVN2652.zip was not found on this server.
Can't get the downlaods for this page:
http://www.riotboard.org/index.php/download
Not Found
The requested URL /linux/Linux.zip was not found on this server.
These links are only a few months old, how are they all gone already.  Anyway any help or suggestions would be great...
  • radiatortwo
    0 radiatortwo over 12 years ago
    Here are some Links that are working.
    Linux: http://downloads.element14.com/downloads/riotboard/Linux/image_SVN2487.zip
    Android: http://downloads.element14.com/downloads/riotboard/Android/image_SVN2597.zip
    Android Tools: http://downloads.element14.com/downloads/riotboard/Android/Tools.zip
    Didn´t see other working links by now.
    It´s really sad that e14 didn´t get anything working by now.
    Months passed and nothing much happened...
  • tusharp
    0 tusharp over 12 years ago
    The guide uses SVN 2487, the image is available here : http://downloads.element14.com/downloads/riotboard/Linux/image_SVN2487.zip.
  • tusharp
    0 tusharp over 12 years ago in reply to tusharp
    no tools...
    Not Found
    for Android tools check this: http://downloads.element14.com/downloads/riotboard/Android/Tools.zip
    you can use  MFG Tools  as otto explained here. Mainline Kernel and U-Boot with MFGTool
    its a nice tutorial.
  • pfinucan
    0 pfinucan over 12 years ago in reply to tusharp
    With the tutorial (RIoTboard: Updating OS images in Windows Environment)  I have SVN 2487.  But the guide assumes you have MfgTool with:
    Profiles\MX6DL Linux Update\OS Firmware.
    When you download from free scale it doesn't have that profile. it has
    Profiles\MX6Q Linux Update
    I get no device detected in MfgTools.  I don't know how to make my own profile.  I have no idea how to make my own xml for flashing the board.
    I tried following Mainline Kernel and U-Boot with MFGTool example but there seems to be some steps that are assumed that I don't know.  What does the finial "cfg.ini"
    look like, it only shows the default.  Do I change that? Do I copy my files into the profile that is there or do I create a new one.  I tried it both ways but get error after error in mfgtools. like:
    Error:
    ModuleID[2] LevelID[1]: Error: Can't find the specified list(Sabre-SD) in the xml file
    ModuleID[2] LevelID[1]: Parse ucl script failed, error code: 12
    Updated cfg.ini to be:
    [profiles]
    chip = MX6Q Linux Update
    [platform]
    board = SabreSD
    [LIST]
    name = i.MX6SOLO-DEBIAN-RIOT-eMMC
    Error:
    .....\Profiles\MX6Q Linux Update\OS Firmware\u-boot-mx6solo-riot.bin failed to open.errcode is 2
    ModuleID[2] LevelID[1]: Parse ucl script failed, error code: 4
    Added u-boot-mx6solo-riot.bin to the MX6Q Linux Update profile.
    Error:
    bootscript failed to open.errcode is 2
    Added bootscript to files
    Error:
    files\zImage failed to open.errcode is 2
    Here I am stuck because I don't have a zImage file and I don't even know where to start looking.
    Any suggestions.  It would be great if there was one totural that worked with a set of files / tools that were avaible in one place.
    Thanks for the help.
  • tusharp
    0 tusharp over 12 years ago in reply to pfinucan
    some files needs to be copied to the mfg tools to continue.
    dl the file from here : https://www.sendspace.com/file/9ijhbb
    file system from here.
    - replace "cfg.ini" in the MFG Tool folder.
    - copy u-boot-mx6solo-riot.bin & uImage & oneiric.tgz to "Profiles/MX6Q Linux Update/OS Firmware/files" folder.
    - copy ucl2.xml to "Profiles/MX6Q Linux Update/OS Firmware" folder
    That should help.
  • tusharp
    the blogs and documents had valid links, but now they are removed.
    yocto based BSP will be available soon .
  • radiatortwo
    0 radiatortwo over 12 years ago in reply to pfinucan
    When downloading the images you don´t need to change anything except for changing the filename from ucl2.txt to ucl2.xml.
    My tutorial is for flashing a self compiled mainline kernel with a bootscript and your own rootfs.
    If you have no device connected, make first sure you use the usb port on the board by the ethernet port.
    Also that the dip switches are set correctly. (1 and 5 Off)
    If still no device, then look into the Windows Device Manager.
    There should be an unknown device.
    Then try to install the driver manually.
    You´ll find it under Standard System devices.
    It´s the HID-Conform from producer defined device.
    (Or similar. Don´t know how it´s named in the english version of Windows)
  • radiatortwo
    0 radiatortwo over 12 years ago in reply to tusharp
    Ok didn´t know that there are files missing in these packages.
  • tusharp
    0 tusharp over 12 years ago in reply to radiatortwo
    my bad english image,  i meant certain setting needs to be change.
    i was trying to provide a simple copy/paste solution to user.
    sry for any confusion caused  image.
  • tusharp
    two more MFG Tools download link:
    Mfgtools_SVN2591 : contains Ubuntu File System
    Mfgtools_SVN2777 : Yocto based
    patrick,
    are you able to setup linux boot ??
