RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Forum spidev
  • Replies 8 replies
  • Subscribers 24 subscribers
  • Views 1461 views
spidev
Is spidev enabled for RIoT?  I have a mikroBUS SPI peripheral and would like to use it on the Adaptor board via spidev.  Bit-banging is the backup option.
  • tusharp
    0 tusharp over 12 years ago
    spidev is not enabled by default.
    it needs to be manually enabled at  "CONFIG_SPI_SPIDEV" in menuconfig.
    0 e14 Contributor over 12 years ago in reply to tusharp
    Thanks.  I was hoping for a device tree overlay to apply at runtime, but if building a kernel is required then bit-bang it is.
    For what it's worth I'm using the out-of-the-box Android build with ro.build.id=1.0.0-rc2 and
    ro.build.version.incremental=20131108
  • tusharp
    0 tusharp over 12 years ago in reply to e14 Contributor
    can you share the module name ??
    any click boards ??
    Click ADC.   I'm using the supplied code that bit-bangs, but noticed the other platform uses spidev so was curious to try that on Riot.
  • tusharp
    Note Taken on spidev,  will get it enabled in next release.
    Hi ! maybe this may work for you, https://community.freescale.com/message/309184#309184, i enabled spidev for my riot based on this thread , this one is for the marsboard but just a little tweak here and there and it should work for riot image
    @tushar - that'll be good to have spidev out-of-the box
    @adroid - thanks but I'm not interested in building my own kernel
    As for my status, I already have bit-bang running on Click ADC.  It's good enough for what I need, though spidev is of course a cleaner approach.
    0 e14 Contributor over 11 years ago in reply to tusharp
    @tushar has this been implemented yet? I am interested in using the thermoclick over SPI interface. If this has not been implemented how can I enable it myself?
