RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Documents Click to Add More Features to your RIoTboard
Join RIoTboard to participate - click to join for free!
  • Author Author: bluescreen
  • Date Created: 29 Sep 2014 6:35 PM Date Created
  • Last Updated Last Updated: 8 Dec 2014 9:22 PM
  • Views 1789 views
Start with the RIoTboard Adapterimage
Buy Now
The RIoTboard adapter provides an interface between MikroElektronika's Click boards to the RIoTBoard .
image  Bottom-side connection to the RIoTboard's 40-pin EXT connector
image  Connector interface for Arduino UNO R3 compatible shield
image  Easily add more features like Bluetooth, ADC, temperature and humidity functions via Click boards.
image  Two connector interfaces for Pmod (type 2/2A) accessories
image  Supports 3.3V and 5V
Tech Specs image
Now Available!  Add on Click Boards
Bluetooth Click
Buy More Info image
Thermo Click
Buy More Info image
SHT11 Click
Buy More Info image
Analog to Digital (ADC) Click
Buy More Info image
BEE Click
Buy More Info image
GPS Click L10
Buy More Info image
GSM Click
Buy More Info image
Click boards are plug-and-play modules designed to add extra functionality to existing development kits.  These small, function-specific add-on boards/modules all have a common interface to the mikroBUSTm adapter board.  Multiple Click boards can also be used simultaneously to enable many features to be implemented at the same time.  These Click boards offer a dual power design, 3.3V and 5V, taking the issue of power supply out of the equation.
There are over 70 Click Boards available allowing developers to easily implement features such as Bluetooth, temperature sensing, humidity sensing and analog-to-digital conversion.  Here’s four we’re featuring now – check back for updates as we add more Click Boards to the list!http://www.element14.com/community
Buy Now
Bluetooth Click
image  Fully certified Class 1 Bluetooth 2.1 + EDR module
image  Bluetooth SIG qualified
image  UART (SPP or HCI) and USB (HCI only) data connection hardware interfaces
image  Supports Bluetooth data link to iPhone/iPad/iPod Touch
Tech Specs imagehttp://www.element14.com/community
Buy Now
Thermo Click
image  Cold-Junction Compensation
image  14-Bit, 0.25°C Resolution
image  Simple SPI-Compatible Interface (read-Only)
image  Detects Thermocouple Shorts to GND or VCC
Buy Now
SHT11 Click
image  Temperature can be represented in 12-bit or 14-bit format in operating range from -40 to +100°C with accuracy of +/-0.5°C at room temperature
image  Humidity can be represented in 8-bit or 12-bit resolution with +/-3% accuracy
image  Typical standby, 400nA max
Buy Now
image  12 bit ADC converter (Microchip MCP3204)
image  Up to 50k samples per second
image  4 input channels
Buy Now
BEE Click
image  2.4GHz IEEE 802.15.4 Transceiver module supports ZigBeeTm, MiWiTm, and MiWi P2P protocols
image  FCC (USA), IC (Canade), ETSI (Europe) Certified
image  Integrated PCB Antenna with simple four-wire SPI interface to PICRegistered microcontroller
image  Low current consumption (Tx 23mA, Rx 19mA, Sleep 2uA)
image  Hardware CSMA-CA Mechanism
image  Automatic ACK response
image  Hardware security engine (AES-128)
Learn More imagehttp://www.element14.com/community
Buy Now
GPS Click L10
image  210 PRN channels
image  66 search channels
image  22 simultaneous tracking channels
image  -165dBm tracking sensitivity
image  Highest autonomous mode acquisition sensitivity, -148dBm
image  Low tracking power consumption, 38mA (passive antenna)
image  Up to 5Hz update rate
image  Embedded with one 4Mbits flash memory
Buy Now
GSM Click
image  Supports GSM/GPRS protocol stack 3GPP
image  Supports GSM/GPRS 850/900/1800/ 1900 MHz Quad-band frequency
image  On-board antenna connector
image  3.5mm quadrupole earphone/microphone jack
image  SIM card socket integrated at the bottom side of the board
image  Easy integration with mikroBUSTm form factor
image  Supported in all mikroElektronika compilers
Tech Specs image
Other Accessories to Extend your RIoTBoard’s Features
Buy Now
WiFi Dongle
Adding WiFi to your board is as simple as plugging in this dongle into a USB port.
image  Uses latest 802.11n technology
image  Supports data rates up to 150Mbps
image  Supports wireless roaming
Tech Specs image
Buy Now
4.3" LCD Module and Adapter Board
image  TFT-LCD Module with 16/24-bit RGB parallel conversion board
image  TSC2046 chip for touch functionality
image  3.3V regulation chip with I2C control capability and PWM backlight
image  Supports 16- and 24-bit driving modes for LCD displays
image  4-wire SPI resistive touch screen
Tech Specs image
Buy Now
9.7" LCD Module
image  Capacitive Multi-Touchscreen
image  1024 x 768 Resolution
image  LVDS Signal
image  Expands to USB Hub
Tech Specs image
Buy Now
UART8000-U - A USB to Serial Debugging Cable
This cable converts from USB to 3-pin TTL allowing for simple and quick debugging of devices compatible with your RIoTBoard.  It is also suitable for serial communications at TTL voltage levels.
Tech Specs image
What Software Works with Click Boards?
µC/Probe Tm Graphical Live WatchTm
Micrium’s µC/Probe is a Windows application that allows you to read and write the memory of any embedded target processor during run-time, and map those values to a set of virtual controls and indicators placed on a graphical dashboard.
Absolutely no programming is required – simply drag and drop the graphic components into place, and watch them go.
This software is a must-have runtime agnostic tool to display and control just about any I/O variable in a target system thru rich graphical objects on the host computer. No code on target needed when using JLINK or select JTAG interfaces.  Tech Specs image
  • bluetooth
  • mikrobus_cape
  • accessory
  • humidity
  • mikrobus
  • temperature
  • riotboard
  • click
  • click_board
  • riotboard_accessory
  • adc
