Freescale i.MX6 Development Platforms
  • Single-Board Computers
  • Freescale i.MX6 Development Platforms
Forum sabrelite I2c
Join Freescale i.MX6 Development Platforms to participate - click to join for free!
  • Subscribers 4 subscribers
  • Views 574 views
sabrelite I2c
I am configuring i2c3.I am using GPIO5, and GPIO16 for SCL and SDA.
I am using default settings in all other registers except I am configuring these registers
IOMUXC_SW_MUX_CTL_PAD_EIM_DATA17
IOMUXC_SW_MUX_CTL_PAD_EIM_DATA18
IOMUXC_SW_PAD_CTL_PAD_EIM_DATA17
IOMUXC_SW_PAD_CTL_PAD_EIM_DATA18
IOMUXC_I2C3_SCL_IN_SELECT_INPUT
IOMUXC_I2C3_SDA_IN_SELECT_INPUT
and Iam enabling clock from CCGR2[10,11] and then using all registers of I2c controller adr,ifdr,i2sr,i2cr,i2cdr
I am not getting any data on my pins always zero.....
Can you please guide me ,Is there any other configuration needed? OR on what side the problem may be?
Also, is there any place where Linux BSP or source code of i2c  are available
Thanks in advance
jumshed63@gmail.com
    http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/tree/drivers/i2c/busses/i2c-imx.c?h=imx_3.0.35_12.09.01
    If you can, use the in-kernel driver. If not then at least you have a starting point that you know should be working.
