Freescale i.MX6 Development Platforms
  • Single-Board Computers
  • Freescale i.MX6 Development Platforms
Forum What a disapointment...
Join Freescale i.MX6 Development Platforms to participate - click to join for free!
  • Subscribers 6 subscribers
  • Views 684 views
  • sabre
  • 6quad
  • lite
  • i.mx
Mechanically very very poorly designed (made in China after all, by a very "experienced" embedded development company...yeah right) - the 2 mounting holes in the corners of the board are either obstructed at the top by the connector or a component underneath.
A bit of common sense and those flaws could have been easily avoided - move everything away from the mounting holes to leave enough clearance !
Also, 3-pin power supply for SATA disk is having the wrong orientation - try putting a connector into that socket and have the whole board in some kind of enclosure...doh...
On top of that, SATA data connector is on different edge of the PCB...facing upwards....hello ?
And why is SD connector mounted right on the edge? so when you slot the card in it sticks out almost 20mm like a sore thumb...doh
The biggest of annoyances/frustrations - buying a £153.x kit in UK and getting a US plug !!! Hello ??? We use UK plugs in UK in case you did not know !!!
Overall out of the box experience (before even plugging it in) is 0 out of 10 !!!
    e14 Contributor over 13 years ago +3
    First off, it's a development board not something designed to be put into an enclosure or into an end product. If that's what you're looking for try the Boundary devices Nitrogen6X. There's a photo of…
  • morgaine
    morgaine over 13 years ago in reply to e14 Contributor +1
    I've been giving this board some serious consideration because of its somewhat rare combination of quad core, SATA and gigabit Ethernet, but from what you say it does have some downsides. Although I too…
    First off, it's a development board not something designed to be put into an enclosure or into an end product. If that's what you're looking for try the Boundary devices Nitrogen6X. There's a photo of it in it's enclosure here http://boundarydevices.com/products/nit6x_enc/
    Given that everything you describe as a flaw is easily seen on the many photos available, you really only have yourself to blame for not doing enough research before buying one.
    Knock, Knock ???
    According to YOUR theory, the likes of Raspberry PI, Beagle Bone, etc are NOT development boards then...
    https://www.google.com/search?q=raspberry+pi+enclosure&source=lnms&tbm=isch&sa=X&ei=r-CkUbHjHY_s0gXjmICIDg&ved=0CAoQ_AUoAQ&biw=1222&bih=896
    https://www.google.com/search?q=beagle+bone+blck+enclosure&um=1&ie=UTF-8&hl=en&tbm=isch&source=og&sa=N&tab=wi&ei=xuCkUfnIENLB0gX55YDABQ&biw=1222&bih=896&sei=3eCkUeudI6Wd0QXrwYCYDQ
    Mechanically, all I want from the board is threaded spacers of my choice, not the plasticky bits provided. Moving a component or a connector 2mm away from the drillling hole during PCB layout is not a rocket science.
    I also wonder why if a buy any electrical appliance in UK, i get a UK plug...I guess someone has thought about it....
  • morgaine
    I've been giving this board some serious consideration because of its somewhat rare combination of quad core, SATA and gigabit Ethernet, but from what you say it does have some downsides.  Although I too am in the UK, the non-UK plug wouldn't be a showstopper for me  if the rest of the product is good enough.  It is somewhat pricy though, so any other downsides reduce its appeal a bit.
    I hope Element 14 is listening to your feedback.  It sounds like their first iteration of the board has some small niggles.  Even if the problems are small, if they exist then highlighting them is helpful to anyone evaluating whether to buy it.  That applied even at the Pi's $25-$35 price point, so it applies even more at higher prices.
