Freescale i.MX6 Development Platforms
  • Single-Board Computers
  • Freescale i.MX6 Development Platforms
Forum How do enable in the second uart port on the sabre lite board
Join Freescale i.MX6 Development Platforms to participate - click to join for free!
  • Subscribers 6 subscribers
  • Views 1686 views
I am trying to output data from my application through the serial port on the Sabre lite board. I need to enable the UART port for the  board so my API  can output the data.Is there a boot command I can use enable the UART, through the U-boot? I am using 08-09 version of U-boot and using an android OS (4.0).
  • clem57
    0 clem57 over 11 years ago
    May first want check out http://boundarydevices.com/u-boot-2013-10-release-2/ to get a later version. Make sure it works with your board revision!image
    0 e14 Contributor over 11 years ago in reply to clem57
    When I try an upgrade I get the an error that says upgradeu not defined
  • clem57
    0 clem57 over 11 years ago in reply to e14 Contributor
    Are you following these directions? https://www.eewiki.net/display/linuxonarm/i.MX6x+SABRE+Lite+SPI+Flash+Recovery
    I managed to load the U-boot but now the android images will no load on the board. Every time boot from the SD card I get an error saying the CPU has stopped. I also tried extracting an image from the website and putting it on an sd card and I have had no luck.
