WaRP7
  • Single-Board Computers
  • WaRP7
WaRP7
Forum LPDDR3 Routing: Strobe lines longer than clock lines on the same layer?
Join WaRP7 to participate - click to join for free!
  • Subscribers 6 subscribers
  • Views 1002 views
  • warp7-cpu-board
noeliascotti
noeliascotti over 9 years ago
Hello! I was analyzing the LPDDR3 routing with the Allegro Free Physical Viewer. I saw weird things...  There are strobe lines longer than clock lines, for example strobe0 836 mils and clock 413 mils on the same layer L4. I understand that max strobe length is clock length - 10 mils.
There is one address line with 273 mils and another one with 434 mils on the same layer L2.
I don't understand this, how is it possible?
  • saravananeceait
    0 saravananeceait over 9 years ago
    Hi Noelia Scotti,
    You have to length match all the single ended DDR signal based on the clock signal length.
    Differential pairs tolerance should be in +- 5 Mils, Single ended signal tolerance should be in +-20 Mils.
    Termination should be placed nearer to the pin.
    You ca refer this DDR design guidelines .
    https://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwjIpdDK99bWAhXBv48KHWxrAG8QFggrMAE&url=https…
  • noeliascotti
    0 noeliascotti over 9 years ago in reply to saravananeceait
    Yes, I know the LPDDR3 routing rules but I want to understand the WARP7 design.
