WaRP7
  • Single-Board Computers
  • WaRP7
WaRP7
Forum warp7 u-boot update
Join WaRP7 to participate - click to join for free!
  • Subscribers 5 subscribers
  • Views 689 views
warp7 u-boot update
wumu
wumu over 9 years ago
hi,I am trying to update the u-boot of the warp7,I fallowed the exactly step in the: https://github.com/WaRP7/WaRP7-User-Guide/blob/master/04-Chapter/U-boot.adoc
the original u-boot information is:
U-Boot 2016.07-00091-ge6b4241 (Aug 22 2016 - 10:56:52 +0800)
CPU:   Freescale i.MX7S rev1.2 at 792MHz
CPU:   Extended Commercial temperature grade (-20C to 105C) at 47C
Reset cause: POR
Board: WARP7
DRAM:  512 MiB
MMC:   FSL_SDHC: 0
In:    serial
Out:   serial
Err:   serial
Net:   CPU Net Initialization Failed
No ethernet found.
Hit any key to stop autoboot:  0
then i use the command:    sudo ./imx_usb u-boot.imx
the newly u-boot infromation is:
U-Boot 2016.07 (Mar 03 2017 - 16:55:17 +0800)
CPU:   Extended Commercial temperature grade (-20C to 105C) at 51C
Reset cause: PORtop autoboot:  6
Board: WARP7
I2C:   ready
DRAM:  512 MiB
PMIC: PFUZE3000 DEV_ID=0x30 REV_ID=0x11
MMC:   FSL_SDHC: 0
In:    serial
Out:   serial
Err:   serial
No ethernet found.
then i fallowed the comand:
=> env default -f -a
=> saveenv
Run the DFU command:
=> dfu 0 mmc 0
and sudo dfu-util -D u-boot.imx -a boot
then the u-boot showed the message:
#DOWNLOAD … OK Ctrl+C to exit …
then i powered off the warp7,put WaRP7 board into normal boot mode,reboot again,the updated u-boot information is :
Reset cause: POR
Board: WARP7
DRAM:  512 MiB
MMC:   FSL_SDHC: 0
In:    serial
Out:   serial
Err:   serial
No ethernet found.
nothing changed??? why?
  • tbsi
    tbsi over 9 years ago
    hi wumu
    FYI : Warp7 Yocto : Part1 : setup, configure and generate Warp7 binaries
    Ta si
