Software
  • Software
Software
Forum Github Template repository: get updates from origin
Join Software to participate - click to join for free!
  • Subscribers 26 subscribers
  • Views 4862 views
  • tutorial
  • github
  • version_control
  • learning
  • git
  • gitlab
  • github_repository
Jan Cumps
Jan Cumps over 2 years ago
When you create a Github repository from a Template, there is no origin <> destination relationship. They live separate lives. This is different from Forking a repository. In that case the fork knows its origin, and you can sync your Fork from the origin.
I would like to update my repository from the original template though. Because that repository gets bug fixes, and I want to inherit them.
  • The Original template repo: https://github.com/jancumps/pst_rtos
  • My repository that's based on that template: https://github.com/jancumps/pst_rtos_xiao
I have been looking for solutions. I found a few custom Github actions that can do this. But they fail if there's a merge conflict. And because it's a job, you can't interactively resolve that. Then I found a solution on Stack Overflow that uses the git command. It worked for me:
I'm looking for feedback. Do you think that this will corrupt the pst_freertos_xiao repo?
The Stack Overflow page lists the side effects, and I've read them. It also has different suggestions, e.g.: patching ...
I started a command line, and navigated to the root of pst_rtos_xiao repository clone on my hard disk.
Then I executed these commands:
$ git pull
$ git remote add template https://github.com/jancumps/pst_rtos.git
$ git fetch --all
$ git merge template/main --allow-unrelated-histories
If merge conflicts occcur, this would be where you fix them.
$ git status
$ git add CMakeLists.txt
$ git add source/scpi/scpi-def.h
$ git commit -a -m "refreshing from template"
$ git push
This merged all changes in my oinline Github repo https://github.com/jancumps/pst_rtos_xiao. That was the goal.
  • embeddedguy
    embeddedguy over 2 years ago +1
    I do not know if I am right or wrong but merge conflict occurs if you push something upstream without first pulling the master branch/head of a particular repo. Also, while pulling you need to stash…
  • embeddedguy
    embeddedguy over 2 years ago in reply to Jan Cumps +1
    But I think git is smart nowadays, if it thinks there is something not updated during push or pull, it will give some form of error or warnings. If someone still ignores it by doing force pull, then…
  • embeddedguy
    Also, while pulling you need to stash your local changes and then do the merge manually.
    Then it will work...A bit complex process that I forget and repeat some exercise to remind myself.
    Jan Cumps over 2 years ago in reply to embeddedguy
    Stashing, I try to avoid by only doing this activity when my local repository is in sync with the online one.
    Then I only need to focus on what changed in the template.
    Merge conflicts happen if the source is changed on both sides, and git can't figure out how to merge them together.
    I think that in case of merging template changes to a derived repo, the chances of having that are fairly high. But the future will tell...
  • embeddedguy
    If someone still ignores it by doing force pull, then surely, there will be conflict.
    It's those merge warnings (errors) that I want. Because I'll have to resolve those to keep the downstream project working, without overriding changes over there ...
