Technical Library
  • Technical Library
Technical Library
Documents Altera Cyclone III FPGA Architecture Overview
  • Author Author: atomar
  • Date Created: 7 Jun 2012 9:06 AM Date Created
  • Last Updated Last Updated: 27 Jun 2012 12:25 AM
  • Views 2092 views
CycloneRegistered III FPGAs offer an unprecedented combination of low power, high functionality, and low cost. The architecture consists of up to 120K vertically arranged logic elements (LEs), 4 Mbits of embedded memory arranged as 9-Kbit (M9K) blocks, and 200 18x18 embedded multipliers. Cyclone III LS FPGAs have a memory-rich and multiplier-rich floorplan consisting of up to 200K logic elements, 8.2 Mbits of embedded memory, and 396 embedded multipliers.
Both architectures include highly efficient interconnect and low-skew clock networks, providing connectivity between logic structures for clock and data signals. The logic and routing core fabric is surrounded by I/O elements (IOEs) and phase-locked loops (PLLs), as shown below
Key Features
  • Power
  • Density
  • Embedded 18 x 18 Multipliers
  • Embedded Memory
  • Cost-Optimized Architecture
  • Clock Management
Connectivity
  • External Memory Interfaces
  • I/O Flexibility
  • Interface and Protocol Support
  • Signal Integrity
  • On-Chip Termination
Altera adopted a new design methodology to ensure Cyclone III FPGAs would successfully meet low-cost goals for high-volume applications. The traditional "optimization-by-elimination" approach involves reducing the cost of an existing high-density product by eliminating features in software. Although this method is marginally effective in reducing FPGA cost, it does not attain the lowest possible price points for a given die size and package.
Cyclone III FPGAs take advantage of the benefits of 65-nm technology (small die size, high density and low cost) with up to three speed grades higher performance than competing low-cost FPGAs. Cyclone III FPGAs are pad limited. A pad-limited die means the I/O structure is as small as possible, and therefore the die cost is at its lowest. In addition, the Cyclone III FPGAs offer staggered I/O pads, meaning that two rows of I/O pads are interleaved, increasing the number of available I/O pads.
Cyclone III FPGAs were built starting with the careful selection of small form-factor packages that offer sufficient user I/O pins and the lowest-cost structure. From the physical dimensions of the package, the maximum size of a pad-limited die can be determined. The logic is then populated with as many logic elements (LEs), memory blocks, dedicated multipliers, and other customer-defined features as possible, guaranteeing the most functionality in the available area.
Back to top
  • fpga
  • cyclone_iii
  • altera
