Technical Library
  • Technical Library
Technical Library
Documents ARM: Bill of Material (BOM) for Keil MCBSTM32F200/400 Evaluation Board
  • Author Author: atomar
  • Date Created: 27 Jun 2012 5:56 AM Date Created
  • Last Updated Last Updated: 27 Oct 2013 2:30 AM
  • Views 2249 views
S/NoReference DesignatorQuantitySuppliers NameNewark/element14 Order CodeFarnell/element14 Order CodeDescription
1 ADC1 1 BOURNS 04F6228 04F6228
Trimer potentiometer
2 BAT1 1 PANASONIC BATTERIES 15C6530 15C6530 2065165 2065165 Battery
3 C1, C34, C42 3 TAIYO YUDEN 29T3547 29T3547 1894509 1894509 SMD chip capacitor
4 C2, C3, C4, C5, C6, C7, C8, C9, C10, C11, C12, C13, C15, C18, C28, C29, C101, C102, C103, C104 20 AVX 85K9474 85K9474 1785684 1785684 SMD chip capacitor
5 C14 1 AVX 96M1284 96M1284 1856379 1856379 SMD chip capacitor
6 C16 1 AVX 10R6036 10R6036 1327737 1327737 SMD chip capacitor
7 C17 1 AVX 96M1263 96M1263 1396406 1396406 SMD chip capacitor
8 C19, C30, C31, C33, C35, C37, C38, C41, C47, C48, C49, C51, C52, C53, C54, C55, C58, C62, C70, C75, C77, C78, C79, C80, C81, C82, C84, C85, C86, C87, C89, C90, C92, C94, C95, C96, C97, C99, C100, C107, C108, C109, C112, C113, C115, C116, C121, C122, C124 49 AVX 96M1113 96M1113 1327666 1327666 SMD chip capacitor
9 C20, C21, C32, C57, C61, C63, C64, C65, C66, C69, C71, C74, C76, C91, C93, C110, C111, C114, C117 19 MURATA 24R6339 24R6339 1735530 1735530 SMD chip capacitor
10 C22 1 MULTICOMP 06R4466 06R4466 1759466 1759466 SMD chip capacitor
11 C23, C24 2 KEMET 93K6009 93K6009 1288200 1288200 SMD chip capacitor
12 C25, C26, C36, C39, C40, C50, C56, C83, C98, C105, C106 11 AVX 96M1265 96M1265 1658868 1658868 SMD chip capacitor
13 C27, C59, C60 3 TDK 90R7605 90R7605 1844134 1844134 SMD chip capacitor
14 C43, C44 2 KEMET 03C3043 03C3043 1856058 1856058 SMD chip capacitor
15 C45, C46 2 KEMET 03C3037 03C3037 1856057 1856057 SMD chip capacitor
16 C67, C68, C123 3 KEMET 74R1765 74R1765 1800793 1800793 SMD chip capacitor
17 C72, C73 2 AVX 96M1135 96M1135 1327632 1327632 SMD chip capacitor
18 C88, C120 2 AVX 75M3043 75M3043 1547183 1547183 SMD chip capacitor 4 array
19 C118 1 AVX 96M1170 96M1170 1327655 1327655 SMD chip capacitor
20 C119 1 KEMET 70K9076 70K9076 1414575 1414575 SMD chip capacitor
21 CAN1/2 1 MULTICOMP (FORMERLY FROM SPC) 79K4994 79K4994 1186049 1186049 SubD 9 pin, Male connector, Right Angle, THT
22 D1, D2, D3, D4, D5 5 DIODES INC. 12T1465 12T1465 1843668 1843668 Schottky Diode
23 D6 1 FAIRCHILD SEMICONDUCTOR 86K1589 86K1589 7355513 7355513 LL4148LL4148
24 ETH 1 TE CONNECTIVITY / AMP 16M2656 16M2656 1363149 1363149 Pulse Jack
25 HP/Line Out, MIC/Line In 2 SWITCHCRAFT 10N6259 10N6259
AUDIO JACK 3.5MM STEREO SMD
26 IC2 1 NATIONAL SEMICONDUCTOR 14R4582 14R4582 1735793 1735793 42V, 2A Constant On-Time Switching Regulator with  Adjustable Current Limit
27 IC3, IC4 2 STMICROELECTRONICS 89K0627 89K0627 1202826 1202826 800mA LDO linear regulator
28 IC5, IC8 2 STMICROELECTRONICS 26M4749 26M4749 1295311 1295311 Very low capacitance ESD protection
29 IC7, IC9 2 STMICROELECTRONICS 57P1111 57P1111
Enhanced single channel power switches
30 IC10 1 STMICROELECTRONICS 71R7092 71R7092
10/100 real-time Ethernet 3.3 V transceiver
31 IC11 1 CIRRUS LOGIC 47M1750 47M1750
Low Power Codec with Class D Speaker Driver
32 IC12 1 STMICROELECTRONICS 89K0625 89K0625 1564297 1564297 800mA LDO linear regulator
33 IC13 1 CYPRESS SEMICONDUCTOR 83R9512 83R9512
32-Mbit (2 M × 16) Static RAM
34 IC14 1 HYNIX SEMICONDUCTOR 58T1893 58T1893 1907377 1907377 4Gb x16/x8, NAND Flash Memory
35 IC15 1 STMICROELECTRONICS 86T4653 86T4653 1972393 1972393 Dual Interface EEPROM IC
36 IC16 1 NUMONYX 26M1760 26M1760 1224423 1224423 64 Megabit, 32 Megabit  3.0-Volt only Page Mode Flash Memory
37 IC17 1 TEXAS INSTRUMENTS 75C7744 75C7744 1103105 1103105 3.0V TO 5.5V, Low-Power, up to 1Mbps, True RS-232RS-232 Transceiver Using Four 0.1µF External Capacitor
38 IC18 1 TEXAS INSTRUMENTS 75C7744 75C7744 1103105 1103105 3.0V TO 5.5V, Low-Power, up to 1Mbps, True RS-232RS-232 Transceiver Using Four 0.1µF External Capacitor
39 IC19, IC22 2 TEXAS INSTRUMENTS 02H5434 02H5434 1470726 1470726 Octal bus transceiver; 3-state
40 IC23 1 STMICROELECTRONICS 89K0625 89K0625 1564297 1564297 800mA LDO linear regulator
41 IC24 1 TEXAS INSTRUMENTS 13M5302 13M5302 1236352 1236352 Low Voltage Octal Bus Buffer with 3 State Outputs (Non Inverted)
42 IC25 1 STMICROELECTRONICS 90R8987 90R8987 1872924 1872924 MEMS motion sensor:  ultra-stable three-axis digital output gyroscope
43 IC26 1 STMICROELECTRONICS 39T4733 39T4733 1872923 1872923 MEMS digital output motion sensor  ultra low-power high performance 3-axes “nano” accelerometer
44 JTAG 1 TE CONNECTIVITY / AMP 73K6222 73K6222 1164294 1164294 JTAG connector 2,54 mm raster, 20 pin, Male, straight
45 L1, L3, L4, L5, L7, L8 6 MURATA 73M9057 73M9057 1515679 1515679 Inductor SMD
46 L2 1 BOURNS 09J2971 09J2971 1612719 1612719 Shielded power inductor Coilcraft
47 L9 1 MURATA 73M9133 73M9133 1515622 1515622 Inductor SMD
48 L10 1 BOURNS JW MILLER 63K3566 63K3566 1835788 1835788 Coilcraft Inductor
49 MIC1 1 STMICROELECTRONICS 83T7185 83T7185 2082418 2082418 MEMS audio sensor  omni-directional digital microphone
50 OSC1 1 AKER 19P2645 19P2645 1640981 1640981 Crystal oscillator SMD
51 OSC3 1 EPSON TOYOCOM 15R2558 15R2558 1712842 1712842 Crystal oscillator SMD
52 P3, P4 2 MOLEX 40P3750 40P3750 1568022 1568022 USB-micro-AB
53 Q1 1 TXC 86R1542 86R1542 1866019 1866019 Quarz crystals
54 Q2 1 EPSON TOYOCOM 55T6304 55T6304 1907466 1907466 32.768 kHz crystals
55 R1, R29, R30, R31, R32, R34, R67, R91, R98, R106, R107, R108, R110 13 VISHAY DALE 36C9017 36C9017 1652824 1652824 SMD chip resistor
56 R3 1 VISHAY DALE 52K6725 52K6725 1150890 1150890 SMD chip resistor
57 R4 1 VISHAY DALE 72M6794 72M6794 1563598 1563598 SMD chip resistor
58 R5 1 PANASONIC ACCESSORIES 08N2426 08N2426 1577544 1577544 SMD chip resistor
59 R6, R15, R16, R24, R33, R47, R54, R56, R57, R59, R61, R68, R73, R76, R79, R82, R86, R87, R88, R89, R94, R95, R96, R97, R100, R101, R102, R112, R113 29 VISHAY DALE 52K6595 52K6595 1358069 1358069 SMD chip resistor
60 R7, R8 2 VISHAY DALE 52K6595 52K6595 1358069 1358069 SMD chip resistor
61 R9, R10, R62, R71, R72, R84, R93 7 BOURNS 61J4729 61J4729 1711701 1711701 Resistor array 4x SMD singleRsymbol, SMD 0804 chip 4 x resistor array
62 R11, R38, R39, R41, R42, R45 6 VISHAY DALE 72M6759 72M6759 1127188 1127188 SMD chip resistor
63 R12 1 VISHAY DALE 52K6646 52K6646 1358071 1358071 SMD chip resistor
64 R13, R23 2 VISHAY DALE 52K6981 52K6981 1358028 1358028 SMD chip resistor
65 R14, R18, R25, R26 4 VISHAY DALE 52K7097 52K7097 1358087 1358087 SMD chip resistor
66 R17, R22 2 VISHAY DALE 89M6686 89M6686 1570688 1570688 SMD chip resistor
67 R20, R21 2 VISHAY DALE 89M6604 89M6604 1357991 1357991 SMD chip resistor
68 R27, R28, R55, R58, R60, R74, R75 7 VISHAY DALE 36C9017 36C9017 1652824 1652824 SMD chip resistor
69 R36, R37 2 VISHAY DALE 52K6853 52K6853 1358024 1358024 SMD chip resistor
70 R40 1 VISHAY DALE 52K6981 52K6981 1358028 1358028 SMD chip resistor
71 R43, R44 2 PHYCOMP 98K8113 98K8113 9235388 9235388 SMD 0804 chip 4 x resistor array
72 R46 1 VISHAY DALE 52K7121 52K7121 1151327 1151327 SMD chip resistor
73 R48, R49 2 VISHAY DALE 72M6772 72M6772 1127232 1127232 SMD chip resistor
74 R50, R51, R90, R99, R111 5 VISHAY DALE 52K6609 52K6609 1358015 1358015 SMD chip resistor
75 R52, R53, R92 3 VISHAY DALE 52K6607 52K6607 1358096 1358096 SMD chip resistor
76 R63, R103 2 VISHAY DALE 52K6575 52K6575 1358047 1358047 SMD chip resistor
77 R65, R109 2 VISHAY DALE 52K7132 52K7132 1469726 1469726 SMD chip resistor
78 R70 1 VISHAY DALE 72M6750 72M6750 1127121 1127121 SMD chip resistor
79 R77, R83, R85 3 BOURNS 32K0368 32K0368
80 R80 1 VISHAY DALE 72M6750 72M6750 1127121 1127121 SMD chip resistor
81 R81 1 VISHAY DALE 52K6721 52K6721 1358020 1358020 SMD chip resistor
82 R104 1 VISHAY DALE 72M6764 72M6764 1563905 1563905 SMD chip resistor
83 R105 1 VISHAY DALE 52K6545 52K6545 1358043 1358043 SMD chip resistor
84 RESET, TAMPER, USER, WAKEUP 4 OMRON ELECTRONIC COMPONENTS 58P0447 58P0447 1695875 1695875 Tact switch C&K SMD
85 SD 1 AMPHENOL COMMERCIAL PRODUCTS 60R0752 60R0752 1788488 1788488 Amphenol 10-100660 micro SD card connector
86 SW1 1 MULTICOMP 31M5582 31M5582 1316987 1316987 TACT switch, Alps, 4 direction, center push, SMD
87 T1, T2 2 NTE ELECTRONICS 06M7374 06M7374 1325356 1325356 45 V, 100 mA NPN general-purpose transistors
88 UART1/3/4 1 MULTICOMP (FORMERLY FROM SPC) 79K4966 79K4966 1186018 1186018 SubD 9 pin, Female connector, Right Angle, THT
89 USBFS, USBHS 2 MULTICOMP 46P5302 46P5302 1696534 1696534 USB 1.1, Right Angle, Thru-Hole, A Type, Receptacle, 4 Position
90 Cortex Debug 1 Samtec Newark/element14 Click Here Farnell/element14 Click Here KEIL 10 pinSWD-7: SW Debug connector, 10 pole, vertical, Male, missing pin 7
91 Cortex Debug + ETM 1 Samtec
Farnell/element14 Click Here KEIL 20 pinSWD-7: SW Debug connector, 20 pole, vertical, Male, missing pin7
92 ETH_SPEED, VBUS_HS 2
Newark/element14 Click Here Farnell/element14 Click Here LED: LED0805 - GREEN
93 FS_ERR, HS_ERR, PG6, PG7, PG8, PH2, PH3, PH6, PH7, PI10 10
Newark/element14 Click Here Farnell/element14 Click Here LED: LED0805 - RED
94 J1 1 Samtec
Newark/element14Click Here
Farnell/element14 Click Here Header J 1x3
95 J2 1 Samtec
Farnell/element14 Click Here Header J 1x2
96 J3 1 Samtec Newark/element14 Click Here Farnell/element14 Click Here Header J 1x3
97 J4 1 Samtec Newark/element14 Click Here Farnell/element14 Click Here Header J 1x3
98 J5 1 Samtec Newark/element14 Click Here Farnell/element14 Click Here Header J 1x2
99 J6 1 Samtec Newark/element14 Click Here Farnell/element14 Click Here Header J 1x2
100 J7 1 Samtec Newark/element14 Click Here Farnell/element14 Click Here Header J 1x2
101 J8 1 Samtec Newark/element14 Click Here Farnell/element14 Click Here Header J 1x2
102 J9 1 Samtec Newark/element14 Click Here Farnell/element14 Click Here Header J 1x2
103 J10 1 Samtec Newark/element14 Click Here Farnell/element14 Click Here Header J 1x3
104 J11 1 Samtec Newark/element14 Click Here Farnell/element14 Click Here Header J 1x3
105 J12 1 Samtec Newark/element14 Click Here Farnell/element14 Click Here Header J 1x3
106 J13 1 Samtec Newark/element14 Click Here Farnell/element14 Click Here Header J 1x3
107 J14 1 Samtec Newark/element14 Click Here Farnell/element14 Click Here Header J 1x3
108 J15 1 Samtec Newark/element14 Click Here Farnell/element14 Click Here Header 2x3. 2 jumper (1+3, 2+4)
109 J16 1 Samtec Newark/element14 Click Here Farnell/element14 Click Here Header J 1x2
110 J17 1 Samtec Newark/element14 Click Here Farnell/element14 Click Here Header J 1x2
111 J18 1 Samtec Newark/element14 Click Here Farnell/element14 Click Here Header J 1x2
112 J19 1 Samtec Newark/element14 Click Here Farnell/element14 Click Here Header J 1x2
113 J20 1 Samtec Newark/element14 Click Here Farnell/element14 Click Here Header J 1x2
114 PWR 8-12V 1 Samtec Newark/element14 Click Here Farnell/element14 Click Here KLD-0202: Low Voltage Power Supply Connector
115 VBUS_FS 1
