Technical Library
  • Technical Library
Technical Library
Documents Texas Instrument: JTAG Adapter Module
  • Author Author: atomar
  • Date Created: 14 Aug 2012 8:38 AM Date Created
  • Last Updated Last Updated: 28 Oct 2013 6:32 AM
  • Views 614 views
The JTAG Adapter Module with flexible cable that is designed to convert between the new ARM mini-JTAG connector  and the standard ARM JTAG connector . With the included flexible 10-pin cable, it can easily connect to small modules using the 10-pin mini-JTAG connector in nearly any orientation.
Product Name
Description
MPN:MDL-ADA2MDL-ADA2
10-pin to 20-pin JTAG Adapter Module
Image:image
The convenient MDL-ADA2MDL-ADA2 is a 10-pin to 20-pin JTAG Adapter Module with flexible cable that is designed to convert between the new ARM mini-JTAG connector (10-pin) and the standard ARM JTAG connector (20-pin). With the included flexible 10-pin cable, it can easily connect to small modules using the 10-pin mini-JTAG connector in nearly any orientation.
Features:
  • Board with 20-pin standard ARM JTAG header socket and 10-pin ARM mini-JTAG socket
  • Convenient reset button for JTAG reset
  • Flexible cable for 10-pin to 10-pin connectivity in any orientation
  • jtag
  • texas_instrument
  • adapter_module
  • mdl-ada2
  • mini-jtag
