Technical Library
  • Technical Library
Technical Library
Documents Freescale: TWRPI-MMA6900 Automotive Low-g Accelerometer Plug-In for the Tower System
  • Author Author: atomar
  • Date Created: 31 Jul 2012 10:20 AM Date Created
  • Last Updated Last Updated: 10 Jun 2013 9:55 AM
  • Views 996 views
Buy NowBuy NowDevelopment ToolsTechnical DocumentsVideoFeaturesKit Contents
Kit Overview
The Freescale's TWRPI-MMA6900TWRPI-MMA6900 is a Tower System plug-in board that contains the Xtrinsic MMA6900Q inertial sensor that can be used in automotive and industrial applications. The board is designed to interface to the Freescale Tower System, a modular development platform which aids in rapid prototyping and tool-reuse. An integrated Open-Source BDM, software tools, and examples provided with the development board make application development and debug quick and easy.
The MMA6900Q  are dual axis, low g, xy sensors based on Freescale’s HARMEMS technology with an embedded DSP ASIC allowing for additional processing of digital or analog signals. The MMA6900Q has a ±3.5g full-scale range per axis. Xtrinsic MMA6900Q sensors are SafeAssure functional safety solutions.
Take your design to the next level with the Freescale Tower System. Freescale's modular development platform saves you months of development time now and in the future through rapid prototyping and tool re–use.
Interchangeable and reusable modules along with open source design files make it easy to customize your design and reduce low level design giving you more time to focus on differentiated solutions.
Key Applications: Automotive and Industrial Applications
imageFreescale Development KitsimageFreescale Development Tools
Technical Documents
Learning Center
TypeDescription
User GuideFreescale: Quick Start Guide for TWRPI-MMA6900  Tower System
Product BriefFreescale: Product Brief for Freescale Tower System
DatasheetFreescale: Datasheet for High Accuracy Low g Inertial Sensor
Selection GuideFreescale Semiconductor: Selection Guide for FREESCALE Tower System Development Tools
Solution GuideFreescale: Solutions For Tower System
Design Elements
TypeDescription
Schematics
Freescale: Schematic File for TWRPI-MMA6900
Application LibraryFreescale: Application Library for TWRPI-MMA6900 Firmware
Application LibraryFreescale: Application Library for FreeMASTER Serial Communication driver V1.6
Back to top
Video
This video is unavailable.
Back to top
Kit Features
  • MMA6900Q: ±3.5 g (11-bit data sensitivity = 3.43 mg/digit typical at 25 degrees C)
  • Low detection threshold of 8.6 mg (acceleration) or >= 0.5 degrees (angle)
  • Offset tolerance value at 25 degrees C (+/- 30 mg) and over temperature (+/-50 mg)
  • Embedded signal processing including fault and overload diagnostic flagging
  • 11-bits SPI-compatible digital data output
  • Wide operating temperature range from -40 degrees C to +105 degrees C
  • Over-damped transducer
  • Robust 6 x 6 mm QFN package with greater than 100 kHz package resonance frequency
  • Sensitivity in X and Y axes
  • ±3.5 or ±5.0g full-scale range per axis
  • AEC-Q100 qualified, Rev. G, grade 2 (-40 < TA < 105 °C)
  • 50 Hz second order low-pass filter
  • SPI-compatible serial interface
  • Capture/hold input for system-wide synchronization support
  • 3.3 or 5.0V single supply operation
  • On-chip temperature sensor and voltage regulator
  • Bi-directional internal self-test
  • Minimal external component requirements
  • Pb-free 16-pin QFN package
  • Pulse-code modulated output available for device evaluation
Back to top
Kit Contents
The Freescale's TWRPI-MMA6900TWRPI-MMA6900 is supplied with below contents:
  • Plug-in Board
Back to top
  • freescale
  • mma6900q
  • twrpi-mma6900
  • tower_system
