Technical Library
  • Technical Library
Technical Library
Documents Microchip: MCP6031DM-PTPLS MCP6031 Photodiode PICtail Plus Demo Board
  • Author Author: atomar
  • Date Created: 13 Nov 2012 5:45 AM Date Created
  • Last Updated Last Updated: 25 Jun 2014 12:52 AM
  • Views 921 views
BUY NOWBUY NOWTechnical DocumentsVideoFeaturesKit Contents
Kit Overview
The Microchip MCP6031DM-PTPLSMCP6031DM-PTPLS MCP6031MCP6031 Photodiode PICtailTm Plus Demo Board demonstrates how to use a transimpedance amplifier, which consists of MCP6031 high precision op amp and external resistors, to convert photo-current (IS) to voltage. The circuit was not calibrated for absolute accuracy.
The RC low-pass filter that is implemented in this circuit can remove the high frequency noise and interference from the signal path prior to the analog-to-digital (A/D) conversion.
The PICmicroRegistered on the Explorer 16 Development Board communicates with the MCP6031 Photodiode PICtailTm Plus Demo Board and completes the analog-to-digital conversion.
TheMCP6031MCP6031 /2/3/4 family of operational amplifiers (op amps) operate with a single supply voltage as low as 1.8V, while drawing ultra low quiescent current per amplifier (0.9 μA, typical). This family also has low input offset voltage (±150 μV, maximum) and rail-to-rail input and output operation.
The MCP6031MCP6031/2/3/4 family is unity gain stable and has a gain bandwidth product of 10 kHz (typical). These specs make these op amps appropriate for low frequency applications.
The MCP6031MCP6031/2/3/4 family is designed with Microchip’s advanced CMOS process. All devices are available in the extended temperature range, with a power supply range of 1.8V to 5.5V.
Key Applications: Toll Booth Tags, Wearable Products, Battery Current Monitoring, Sensor Conditioning, Battery Powered
imageDevelopment KitsimageDevelopment Tools
Technical Documents
Learning Center
TypeDescription
User GuideMicrochip: User Guide for MCP6031 Photodiode PICtail Plus Demo Board
User GuideMicrochip: Quick Start Guide to Development Tools
Selection GuideMicrochip: Selection Guide for Analog and Interface Products
Selection GuideMicrochip: Selection Guide for Automotive Products
DatasheetMicrochip: Datasheet for MCP6031/2/3/4 - 0.9 uA High Precision Op Amps
Product BriefMicrochip: Product Brief for PGA, Operational Amplifiers and Comparators Design
Product BriefMicrochip: Product Brief for Signal Chain
Application NoteMicrochip: AN951 - Application Note for Amplifying High-Impedence Sensors Photodiode Example
Design Elements
TypeDescription
LayoutMicrochip: Layout File for MCP6031 Photodiode PICtail Plus Demo Board
Application LibraryMicrochip: Software Code for MCP6031 Photodiode PICtail Plus Demo Board
Simulation ModelMicrochip: SPICE Model for MCP6031/2/3/4 Devices
Back to top
Video
Back to top
Kit Features
Key Features for MCP6031DM-PTPLSMCP6031DM-PTPLS Demo Board:
  • Supports Microchip MCP6031 high precision op amp
  • Uses a transimpedance amplifier as sensor conditioning circuit
  • Uses a PIN photodiode (PNZ334) as light detector
  • Test points for connecting lab equipment
Key Features for MCP6031MCP6031, 0.9 μA, High Precision Op Amps:
  • Rail-to-Rail Input and Output
  • Low Offset Voltage: ±150 μV (maximum)
  • Ultra Low Quiescent Current: 0.9 μA (typical)
  • Wide Power Supply Voltage: 1.8V to 5.5V
  • Gain Bandwidth Product: 10 kHz (typical)
  • Unity Gain Stable
  • Extended Temperature Range: -40°C to +125°C
  • No Phase Reversal
Back to top
Kit Contents
The Microchip MCP6031DM-PTPLSMCP6031DM-PTPLS MCP6031 Photodiode PICtail Plus Demo Board is supplied with below contents:
  • MCP6031 Photodiode PICtailTm Plus Demo Board (102-00219)
  • Important Information “Read First”
  • Analog and Interface Products Demonstration Boards CD-ROM (DS21912). It contains:
    • MCP6031 Photodiode PICtailTm Plus Demo Board User’s Guide (DS51763)
    • Firmware files
    • Gerber files
Back to top
  • mcp6031
  • microchip
  • mcp6031dm-ptpls
  • pictail_plus
